8mp使用2515芯片实现SPI转CAN
2023-6-27 14:47| 发布者: wjy| 查看: 702| 评论: 0
类目: 知识库  >  i.MX8MP系列产品     文档编号: 1028
文档编号:911 移植的是2518 SPI转CAN FD芯片,本文移植的是2515 SPI转CAN芯片,只满足普通CAN功能,不支持CAN FD。
说明:OKMX8MP开发板内核源码中已经包含了2515的驱动,直接修改设备树及驱动配置即可。
驱动路径:OK8MP-linux-sdk/OK8MP-linux-kernel/drivers/net/can/spi/mcp251x.c
1.1.1添加驱动配置
forlinx@ubuntu:~/OK8MP-linux-sdk/OK8MP-linux-kernel/$ vi arch/arm64/configs/OK8MP-C_\
defconfig
在任意位置添加:
CONFIG_CAN_MCP251X=y
1.1.2修改设备树
forlinx@ubuntu:~/OK8MP-linux-sdk/OK8MP-linux-kernel/$ vi arch/arm64/boot/dts/freescale/\
OK8MP-C.dts
1. 添加时钟节点:
        model = "Forlinx OK8MPlus-C board";
compatible = "forlinx,ok8mp-c", "fsl,imx8mp-evk", "fsl,imx8mp";
        clocks {                                                //添加时钟节点
                mcp251x_clock: mcp251x_clock{
                        compatible = "fixed-clock";
                        #clock-cells = <0>;
                        clock-frequency = <8000000>;           //对应模块上晶振的频率
        reserved-memory {
                #address-cells = <2>;
2. ecspi2节点下屏蔽之前的子节点spidev1,添加2515的子节点:
&ecspi2 {
        #address-cells = <1>;
        #size-cells = <0>;
        fsl,spi-num-chipselects = <1>;
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_ecspi2 &pinctrl_ecspi2_cs>;
        cs-gpios = <&gpio5 13 GPIO_ACTIVE_LOW>;
        status = "okay";
        spidev1: spi@0 {
                reg = <0>;
                compatible = "rohm,dh2228fv";
                spi-max-frequency = <500000>;
        can0: mcp2515@0 {
                compatible = "microchip,mcp2515";
                reg = <0>;                           //地址从0开始
                spi-max-frequency = <10000000>;      //spi最大频率设置,此处为1MHz
                clocks = <&mcp251x_clock>;                       //使用刚刚写的时钟
                interrupt-parent = <&gpio4>;   //中断引脚配置,中断引脚是GPIO4_IO21
                interrupts = <21 0x2>;     //中断引脚配置,参数0x2代表触发方式
3. 添加中断引脚配置:
pinctrl_ecspi2: ecspi2grp {
fsl,pins = <
MX8MP_IOMUXC_ECSPI2_SCLK__ECSPI2_SCLK 0x82
MX8MP_IOMUXC_ECSPI2_MOSI__ECSPI2_MOSI 0x82
MX8MP_IOMUXC_ECSPI2_MISO__ECSPI2_MISO 0x82
MX8MP_IOMUXC_SAI2_RXFS__GPIO4_IO21 0x40000
4. 编译源码并烧写。
1.1.3开机验证
1. 在开发板上SPI2接口处接上2515转接板,启动开发板。
2. 查看驱动是否成功挂载:
root@OK8MP:~# lsmod
Module Size Used by
can_raw 20480 1
can 28672 1 can_raw
vvcam_video 32768 0
moal 716800 1
mlan 499712 1 moal
cdc_acm 32768 0
xr_usb_serial_common 45056 0
vvcam_isp 69632 1
vvcam_dwe 20480 1
imx8_media_dev 20480 0
basler_camera_driver 16384 0
crct10dif_ce 16384 1
edt_ft5x06 24576 0
basler_camera_driver_vvcam 16384 0
goodix 24576 0
mcp251x 24576 0
flexcan 32768 0
can_dev 36864 2 mcp251x,flexcan
3. 查看是否生成节点:
root@OK8MP:~# ifconfig -a
can0 Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
UP RUNNING NOARP  MTU:16  Metric:1
RX packets:2 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:10
RX bytes:16 (16.0 B)  TX bytes:0 (0.0 B)
Interrupt:31
can1 Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
can2 Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
Interrupt:32
 注意:
使用SPICAN芯片转出的can节点号不确定,可通过排除法确定哪个是SPICAN的节点;
原生CAN节点有中断“Interrupt”,原生CAN1中断值为31,原生CAN2中断值为32,没有中断的即为2515 SPICAN
上述结果中:SPICAN对应软件节点:can1
CAN1对应软件节点:can0
CAN2对应软件节点:can2
1.1.4测试SPICAN的功能
SPICAN与原生CAN1短接进行测试,接线方法如下:
CAN1 H 端子与 SPICAN 设备 H 端子连接;
CAN1 L 端子与 SPICAN 设备 L 端子连接。
1. 设置 CAN 设备 can0 can1 波特率为 500 KHz500000)。
root@OK8MP:~# ip link set can0 type can bitrate 500000 triple-sampling on
root@OK8MP:~# ip link set can1 type can bitrate 500000 triple-sampling on
2. 打开 CAN 设备 can0 can1
root@OK8MP:~# ifconfig can0 up                                         //打开 can0
root@OK8MP:~# ifconfig can1 up                                         //打开 can1
3. 配置 CAN 设备 can0 为接收端、can1 为发送端:
root@OK8MP:~# candump can0 &                               //设置 can0 为接收端
root@OK8MP:~# cansend can1 1F334455#1122334455667788     //设置 can1 发送数据
can0 1F334455 [8] 11 22 33 44 55 66 77 88                    //can0 端接收到数据
发送默认 ID 0x1F334455 CAN 标准帧,数据为 0x11 22 33 44 55 66 77 88
GMT+8, 2026-9-16 02:04
