6254-qt编译程序执行遇到报错
2023-6-29 09:09| 发布者: haiyan| 查看: 631| 评论: 0
类目: AM6254系列产品  >  linux     文档编号: 1029
问题报错:
Failed to create wl_display (No such file or directory)
qt.qpa.plugin: Could not load the Qt platform plugin "wayland" in "" even though it was found.
报错原因:6254屏幕显示有lcd和lvds,出现问题原因:uboot阶段双屏幕都关闭了
解决方法:在启动阶段连续按空格键进入到uboot,开启任一屏幕显示即可
GMT+8, 2026-9-26 21:43
