OK3588Android12系统低电量关机
2023-10-31 14:08| 发布者: whl| 查看: 402| 评论: 0
类目: RK3588系列产品  >  Android     文档编号: 1187
默认电量低于15%会自动关机,如果想要改为低于10%关机,可以做如下修改:
--- a/frameworks/base/services/core/java/com/android/server/BatteryService.java
+++ b/frameworks/base/services/core/java/com/android/server/BatteryService.java
@@ -370,9 +370,13 @@ public final class BatteryService extends SystemService {
     private boolean shouldShutdownLocked() {
-        if (mHealthInfo2p1.batteryCapacityLevel != BatteryCapacityLevel.UNSUPPORTED) {
- return (mHealthInfo2p1.batteryCapacityLevel == BatteryCapacityLevel.CRITICAL);
+       if(mHealthInfo.batteryLevel < 15 && !isPoweredLocked(BatteryManager.BATTERY_PLUGGED_ANY)) {
+               return true;
GMT+8, 2026-8-16 13:31
