6ulx使用USB虚拟网卡
2023-10-31 16:55| 发布者: Espoir| 查看: 231| 评论: 0
类目:  >  知识库     文档编号: 1191
6ulx使用USB虚拟网卡
6ull支持USB虚拟网卡,通过otg连接到pc,在pc中可以成usb虚拟网卡,可以像普通网卡一样传输数据。
1.内核配置
开启虚拟网卡功能,需要配置内核:
> Device Drivers
> USB support
> USB Gadget Support
<M> USB Gadget Drivers
[*] Ethernet Control Model (CDC ECM)
[*] RNDIS
配置后重新编译内核及模块,6ulx Linux4.1.15的内核当中,默认已经开启了以上内容,可以直接按照以下步骤测试。
2.开启虚拟网卡
使用以下命令加载模块驱动:
$ depmod
$ modprobe g_ether
using random self ethernet address
using random host ethernet address
usb0: HOST MAC 9a:da:f1:04:bd:87
usb0: MAC 3e:93:31:de:b3:be
g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
g_ether gadget: g_ether ready
使用ifconifg可以查看到usb0网卡:
$ ifconfig usb0
usb0     Link encap:Ethernet HWaddr 3e:93:31:de:b3:be
        BROADCAST MULTICAST MTU:1500 Metric:1
        RX packets:0 errors:0 dropped:0 overruns:0 frame:
        TX packets:0 errors:0 dropped:0 overruns:0 carrie
        collisions:0 txqueuelen:1000
        RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
设置虚拟网卡的IP:
$ ifconfig usb0 up
$ ifconfig usb0 192.168.3.100
将网卡挂载到虚拟机上的Ubuntu,Ubuntu上可以看到该网卡:
forlinx@ubuntu:~$ ifconfig
ens33: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
      inet 172.16.0.176 netmask 255.255.0.0 broadcast 172.16.255.255
      inet6 fe80::440:9f3c:1bdf:7dcf prefixlen 64 scopeid 0x20<link>
      ether 00:0c:29:04:0c:5a txqueuelen 1000 (Ethernet)
      RX packets 1758930 bytes 325617111 (325.6 MB)
      RX errors 0 dropped 1 overruns 0 frame 0
      TX packets 23984 bytes 4206273 (4.2 MB)
      TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
ens160u2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
      inet6 fe80::cb43:4c6c:14e3:52c5 prefixlen 64 scopeid 0x20<link>
      ether 9a:da:f1:04:bd:87 txqueuelen 1000 (Ethernet)
      RX packets 2 bytes 354 (354.0 B)
      RX errors 0 dropped 0 overruns 0 frame 0
      TX packets 45 bytes 8169 (8.1 KB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
      inet 127.0.0.1 netmask 255.0.0.0
      inet6 ::1 prefixlen 128 scopeid 0x10<host>
      loop txqueuelen 1000 (Local Loopback)
      RX packets 3218438 bytes 298605151 (298.6 MB)
      TX packets 3218438 bytes 298605151 (298.6 MB)
ens160u2即为USB网卡,设置Ubuntu上虚拟网卡IP:
forlinx@ubuntu:~$ sudo ifconfig ens160u2 192.168.3.200
ping测试:
forlinx@ubuntu:~$ ping 192.168.3.200
PING 192.168.3.200 (192.168.3.200) 56(84) bytes of data.
64 bytes from 192.168.3.200: icmp_seq=1 ttl=64 time=0.051 ms
64 bytes from 192.168.3.200: icmp_seq=2 ttl=64 time=0.066 ms
GMT+8, 2026-9-25 13:37
