113-i调屏方法整理
2024-1-29 11:53| 发布者: shuishui| 查看: 348| 评论: 0
类目: T113i系列产品  >  linux     文档编号: 1288
开发平台:飞凌113i-S开发板
113i屏幕修改需要分别修改内核以及uboot,下面我们以lvds1024*600的屏幕为例
1.进入如下路径
forlinx@ubuntu:~/work/OK113i-linux-sdk$ cd kernel/linux-5.4/arch/arm/boot/dts/
2.打开 OK113I-C-Linux.dts
forlinx@ubuntu:~/work/OK113i-linux-sdk/kernel/linux-5.4/arch/arm/boot/dts$ vi OK113I-C-Linux.dts
 3.修改分辨率参数如下面所示(具体参数请参考您使用的屏幕的屏体手册):
elif (DISP_TYPE == 5)
// lvds 1280x800
&lcd0 { lcd_used = <1>; status = "okay";
 lcd_driver_name = "default_lcd";
 lcd_backlight = <150>;
 lcd_if = <3>;
 lcd_x = <1024>;
 lcd_y = <600>;
 lcd_width = <210>;
 lcd_height = <135>;
 lcd_dclk_freq = <71>;
 lcd_pwm_used = <1>;
 lcd_pwm_ch = <3>;
 lcd_pwm_freq = <20000>;
 lcd_pwm_pol = <1>;
 lcd_pwm_max_limit = <255>;
 4.修改完成后保存并退出,然后开始修改uboot,进入如下路径
forlinx@ubuntu:~/work/OK113i-linux-sdk$ cd brandy/brandy-2.0/u-boot-2018/drivers/video/sunxi/bootGUI/
5.打开display-menu.c
forlinx@ubuntu:~/work/OK113i-linux-sdk/brandy/brandy-2.0/u-boot-2018/drivers/video/sunxi/bootGUI$ vi display_menu.c
6.修改分辨率参数如下方所示:
void  bootup_menu_setprop_by_lcd_lvds_1280_800(int kernel)
        int offset_node = 0;
    unsigned int phandle0 = 0;
    unsigned int phandle1 = 0;
    bootup_hal_save_lcd_to_kernel("lcd_used", FDT_UINT_VALUE, 1, NULL);
    bootup_hal_save_lcd_to_kernel("lcd_if", FDT_UINT_VALUE, 3, NULL);
    bootup_hal_save_lcd_to_kernel("lcd_driver_name", FDT_STRING_VALUE, 0, "default_lcd");
    bootup_hal_save_lcd_to_kernel("lcd_x", FDT_UINT_VALUE, 1024, NULL);
    bootup_hal_save_lcd_to_kernel("lcd_y", FDT_UINT_VALUE, 600, NULL);
    bootup_hal_save_lcd_to_kernel("lcd_width", FDT_UINT_VALUE, 210, NULL);
    bootup_hal_save_lcd_to_kernel("lcd_height", FDT_UINT_VALUE, 135, NULL);
    bootup_hal_save_lcd_to_kernel("lcd_dclk_freq", FDT_UINT_VALUE, 71, NULL);
7.修改完成后,在源码初始路径下编译uboot
forlinx@ubuntu:~/work/OK113i-linux-sdk$ ./build.sh brandy
8. 编译成功后进行全编译./build.sh
9.执行成功后./build.sh pack打包镜像烧录到板子上观察现象。
GMT+8, 2025-7-1 10:28
