IMX6Q-CV1.1底板的资料中电容屏和电阻屏的镜像如何配置编译
2017-9-14 17:19| 发布者: 飞凌-unix| 查看: 1726| 评论: 0
类目: I.MX6系列产品  >  Linux     文档编号: 137
以下是patch文件的内容,默认配置是电容屏的,从电容屏的配置修改为电阻屏的配置,可以通过config配置进行修改:
-号表示去掉的内容,+表示添加的内容
diff --git a/arch/arm/configs/imx6_defconfig b/arch/arm/configs/imx6_defconfig
index 962ea1f0..8a2d84b1 100644
--- a/arch/arm/configs/imx6_defconfig
+++ b/arch/arm/configs/imx6_defconfig
@@ -1099,7 +1099,7 @@ CONFIG_INPUT_TOUCHSCREEN=y
 # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
 # CONFIG_TOUCHSCREEN_EETI is not set
 # CONFIG_TOUCHSCREEN_EGALAX is not set
-CONFIG_TOUCHSCREEN_FT5X06=y
+# CONFIG_TOUCHSCREEN_FT5X06 is not set
 CONFIG_TOUCHSCREEN_GT9XX=y
 # CONFIG_TOUCHSCREEN_ELAN is not set
 # CONFIG_TOUCHSCREEN_FUJITSU is not set
@@ -1119,7 +1119,7 @@ CONFIG_TOUCHSCREEN_GT9XX=y
 # CONFIG_TOUCHSCREEN_NOVATEK is not set
 # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
 # CONFIG_TOUCHSCREEN_TSC2005 is not set
-# CONFIG_TOUCHSCREEN_TSC2007 is not set
+CONFIG_TOUCHSCREEN_TSC2007=y
 # CONFIG_TOUCHSCREEN_W90X900 is not set
 # CONFIG_TOUCHSCREEN_ST1232 is not set
 # CONFIG_TOUCHSCREEN_P1003 is not set
GMT+8, 2026-10-5 03:55
