1.335x前边已经移植好了hostapd;直接使用就可以 热点名为rtwap,密码为87654321 2.dhcpd 配置文件修改 创建空文件/var/db/dhcpd.leases mkdir -p /var/db touch /var/db/dhcpd.leases 3. ifconfig eth0 up udhcpc -i eth0 ifconfig wlan0 up ifconfig wlan0 10.5.5.1 netmask 255.255.255.0 echo 1 > /proc/sys/net/ipv4/ip_forward /* 打开IP转发 */ /sbin/iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE 设置网卡的混杂模式 # ifconfig wlan0 promisc [ 3725.324000] device wlan0 entered promiscuous mode dhcpd -cf /etc/dhcpd.conf wlan0 & hostapd /etc/hostapd.conf -B 4.前边命令中需要用到iptables,文件系统中需要移植iptables (iptables编译) ./configure --host=arm-arago-linux-gnueabi --prefix=/root/335x/localcode/iptables/install --disable-nftables --with-ksource=/root/335x/localcode/kernel-3.2.0 --enable-static --disable-shared make make install 编译完成后需要将iptables移植到开发板上; 内核中也需要配置iptables的支持 [*] Networking support ---> Networking options ---> [*] Network packet filtering framework (Netfilter) ---> Core Netfilter Configuration --->(全部选上) IP: Netfilter Configuration ---> (全部选上) |
GMT+8, 2026-9-30 21:22
