| RK3588 Android12修改长按电源按键可弹出关机重启等选项
修改如下: - - - a/frameworks/base/core/res/res/values/config.xml +++ b/frameworks/base/core/res/res/values/config.xml @@ -977,7 +977,7 @@ 4 - Go to voice assist 5 - Go to assistant (Settings.Secure.ASSISTANT) --> - <integer name="config_longPressOnPowerBehavior">5</integer> + <integer name="config_longPressOnPowerBehavior">1</integer> <!-- The time in milliseconds after which a press on power button is considered "long". --> <integer name="config_longPressOnPowerDurationMs">500</integer> |
GMT+8, 2026-9-5 11:44
