1.先删除/var/log
2.打开/etc/default/volatiles/00_core 注释下面代码
l root root 0755 /var/log /var/volatile/log
3.删除 /etc/volatile.cache
4.重新创建/var/log文件
然后重启后log就不会被软连接上了
1.先删除/var/log 2.打开/etc/default/volatiles/00_core 注释下面代码
l root root 0755 /var/log /var/volatile/log 3.删除 /etc/volatile.cache 4.重新创建/var/log文件 然后重启后log就不会被软连接上了 |
GMT+8, 2026-10-8 00:17
