ubuntu20.04显示登入界面,关闭自动登录
2024-7-31 09:18| 发布者: 金色田野的灿烂| 查看: 542| 评论: 0
类目: RK3588系列产品  >  Ubuntu     文档编号: 1469
目前3588的ubuntu20.04的系统是没有登入界面,如果想要打开按照以下操作执行
修改如下:
vi /etc/gdm3/custom.conf      //修改该文件关闭自启动登入
# GDM configuration storage
# See /usr/share/gdm/gdm.schemas for a list of available options.
[daemon]
# Uncomment the line below to force the login screen to use Xorg
#WaylandEnable=false
# Enabling automatic login
AutomaticLoginEnable = false     //修改true为false关闭自动登入
AutomaticLogin = forlinx
# Enabling timed login
# TimedLoginEnable = true
# TimedLogin = user1
# TimedLoginDelay = 10
[security]
[xdmcp]
[chooser]
[debug]
# Uncomment the line below to turn on debugging
# More verbose logs
# Additionally lets the X server dump core if it crashes
#Enable=true
GMT+8, 2026-9-19 00:41
