Android 12 系统横屏时,开机动画有一段时间显示不全
2024-8-30 15:04| 发布者: 金色田野的灿烂| 查看: 795| 评论: 0
类目:  >  知识库     文档编号: 1505
android12由于系统默认方向为竖屏,平板电脑要横屏显示。系统在开机时,有时因为旋转,会出现动画只显示一部分,如下图:
修改如下:
diff --git a/device/rockchip/rk3588/BoardConfig.mk b/device/rockchip/rk3588/BoardConfig.mk
index b25ebb6a6e..c71120e04d 100644
--- a/device/rockchip/rk3588/BoardConfig.mk
+++ b/device/rockchip/rk3588/BoardConfig.mk
@@ -29,7 +29,7 @@ PRODUCT_KERNEL_CONFIG ?= OK3588-Android_defconfig
 PRODUCT_BOOT_DEVICE := fe2e0000.mmc
 PRODUCT_SDMMC_DEVICE := fe2c0000.mmc
-SF_PRIMARY_DISPLAY_ORIENTATION := 0
+SF_PRIMARY_DISPLAY_ORIENTATION := 90
 # Disable emulator for "make dist" until there is a 64-bit qemu kernel
 BUILD_EMULATOR := false
diff --git a/frameworks/native/services/su**ceflinger/DisplayDevice.cpp b/frameworks/native/services/su**ceflinger/DisplayDevice.cpp
index 4445eea604..a3cc781ec5 100644
--- a/frameworks/native/services/su**ceflinger/DisplayDevice.cpp
+++ b/frameworks/native/services/su**ceflinger/DisplayDevice.cpp
@@ -262,13 +262,15 @@ void DisplayDevice::setProjection(ui::Rotation orientation, Rect layerStackSpace
     if (!orientedDisplaySpaceRect.isValid()) {
         // The destination frame can be invalid if it has never been set,
         // in that case we assume the whole display size.
-        orientedDisplaySpaceRect = getCompositionDisplay()->getState().displaySpace.bounds;
+         orientedDisplaySpaceRect = getCompositionDisplay()->getState().displaySpace.bounds;
+         orientedDisplaySpaceRect = Rect(orientedDisplaySpaceRect.bottom, orientedDisplaySpaceRect.right);
     if (layerStackSpaceRect.isEmpty()) {
         // The layerStackSpaceRect can be invalid if it has never been set, in that case
         // we assume the whole framebuffer size.
         layerStackSpaceRect = getCompositionDisplay()->getState().framebufferSpace.bounds;
+        layerStackSpaceRect = Rect(layerStackSpaceRect.bottom, layerStackSpaceRect.right);
         if (orientation == ui::ROTATION_90 || orientation == ui::ROTATION_270) {
             std::swap(layerStackSpaceRect.right, layerStackSpaceRect.bottom);
diff --git a/frameworks/native/services/su**ceflinger/Su**ceFlinger.cpp b/frameworks/native/services/su**ceflinger/Su**ceFlinger.cpp
index 894c47fb91..5ae5a7c1bf 100755
--- a/frameworks/native/services/su**ceflinger/Su**ceFlinger.cpp
+++ b/frameworks/native/services/su**ceflinger/Su**ceFlinger.cpp
@@ -437,9 +437,10 @@ Su**ceFlinger::Su**ceFlinger(Factory& factory) : Su**ceFlinger(factory, SkipI
             internalDisplayOrientation = ui::ROTATION_270;
             break;
-    ALOGV("Internal Display Orientation: %s", toCString(internalDisplayOrientation));
+    //ALOGV("Internal Display Orientation: %s", toCString(internalDisplayOrientation));
     mInternalDisplayPrimaries = sysprop::getDisplayNativePrimaries();
+    ALOGV("Internal Display Orientation: %s", toCString(internalDisplayOrientation));
     // debugging stuff...
     char value[PROPERTY_VALUE_MAX];
@@ -2786,8 +2787,14 @@ sp<DisplayDevice> Su**ceFlinger::setupNewDisplayDeviceInternal(
     display->setLayerStack(state.layerStack);
-    display->setProjection(state.orientation, state.layerStackSpaceRect,
-                           state.orientedDisplaySpaceRect);
+  //  display->setProjection(state.orientation, state.layerStackSpaceRect,
+    if(!mBootFinished){
+        display->setProjection(ui::ROTATION_0, state.layerStackSpaceRect,
+                     state.orientedDisplaySpaceRect);
+    }else{
+        display->setProjection(state.orientation, state.layerStackSpaceRect,
     display->setDisplayName(state.displayName);
     return display;
@@ -2958,8 +2965,15 @@ void Su**ceFlinger::processDisplayChanged(const wp<IBinder>& displayToken,
         if ((currentState.orientation != drawingState.orientation) ||
             (currentState.layerStackSpaceRect != drawingState.layerStackSpaceRect) ||
             (currentState.orientedDisplaySpaceRect != drawingState.orientedDisplaySpaceRect)) {
-            display->setProjection(currentState.orientation, currentState.layerStackSpaceRect,
+ //    display->setProjection(currentState.orientation, currentState.layerStackSpaceRect,
+         ALOGV("%s currentState.orientation=%d", __FUNCTION__,currentState.orientation);
+                display->setProjection(ui::ROTATION_0, currentState.layerStackSpaceRect,
+     currentState.orientedDisplaySpaceRect);
+ }else{
+                display->setProjection(currentState.orientation, currentState.layerStackSpaceRect,
             if (isDisplayActiveLocked(display)) {
                 mActiveDisplayTransformHint = display->getTransformHint();
GMT+8, 2026-9-27 08:18
