编译mx6 linux3.0.35内核出错
2018-5-21 08:50| 发布者: yangy| 查看: 993| 评论: 0
类目: I.MX6系列产品  >  Linux     文档编号: 184
ubuntu16.04 编译mx6 linux3.0.35内核报错:
Can't use 'defined(@array)' (Maybe you should just omit the defined()?) at kernel/timeconst.pl line 373.
/home/yy/forlinx/s2/linux-3.0.35/kernel/Makefile:140: recipe for target 'kernel/timeconst.h' failed
make[1]: *** [kernel/timeconst.h] Error 255
Makefile:945: recipe for target 'kernel' failed
make: *** [kernel] Error 2
make: *** Waiting for unfinished jobs....
把kernel/timeconst.pl line373 defined()去掉
GMT+8, 2026-9-28 17:01
