飞凌RT1052开发板实现SPI接口的OLED屏显示
2018-11-10 09:47| 发布者: jinglixixi| 查看: 2631| 评论: 5|原作者: jinglixixi
类目: 知识库  >  FET1050-C系列产品     文档编号: 235
    这里再介绍一下在飞凌RT1052开发板上使用键盘端口(KPP)来驱动SPI接口OLED屏的用法。
    OLED屏与RT1052的连接关系如下:
CS  --P1.24
DC  --P1.26
RST --P1.28
DIN --P1.27  D1
SCLK--P1.25  D0
    使个引脚输出高低电平的定义如下:
#define OLED_CS_Clr()       GPIO_PinWrite(GPIO1, (24U), 0U);
#define OLED_CS_Set()       GPIO_PinWrite(GPIO1, (24U), 1U);
#define OLED_DC_Clr()       GPIO_PinWrite(GPIO1, (26U), 0U);
#define OLED_DC_Set()       GPIO_PinWrite(GPIO1, (26U), 1U);
#define OLED_RST_Clr()      GPIO_PinWrite(GPIO1, (28U), 0U);
#define OLED_RST_Set()      GPIO_PinWrite(GPIO1, (28U), 1U);
#define OLED_SDIN_Clr()     GPIO_PinWrite(GPIO1, (27U), 0U);
#define OLED_SDIN_Set()    GPIO_PinWrite(GPIO1, (27U), 1U);
#define OLED_SCLK_Clr()     GPIO_PinWrite(GPIO1, (25U), 0U);
#define OLED_SCLK_Set()     GPIO_PinWrite(GPIO1, (25U), 1U);
   配置各引脚为输出端口的函数为:
void LCD_GPIO_Cogfig(void)
    gpio_pin_config_t led_config = {kGPIO_DigitalOutput, 0, kGPIO_NoIntmode};
    GPIO_PinInit(GPIO1, (25U), &led_config);
    GPIO_PinInit(GPIO1, (27U), &led_config);
    GPIO_PinInit(GPIO1, (24U), &led_config);
    GPIO_PinInit(GPIO1, (26U), &led_config);
    GPIO_PinInit(GPIO1, (28U), &led_config);
    GPIO_PinInit(GPIO1, (30U), &led_config);
    GPIO_PinInit(GPIO1, (31U), &led_config);
该OLED屏的初始化函数为:
void OLED_Init(void)
    LCD_GPIO_Cogfig();
    OLED_RST_Set();
    delay_ms(100);
    OLED_RST_Clr();
    delay_ms(100);
    OLED_RST_Set();
    OLED_WR_Byte(0xAE,OLED_CMD);//--turn off oled panel
    OLED_WR_Byte(0x00,OLED_CMD);//---set low column address
    OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
    OLED_WR_Byte(0x40,OLED_CMD);//--set start line address  Set Mapping RAM    OLED_WR_Byte(0x81,OLED_CMD);//--set contrast control register
    OLED_WR_Byte(0xCF,OLED_CMD); // Set SEG Output Current Brightness
    OLED_WR_Byte(0xA1,OLED_CMD);//--Set SEG/Column Mapping
    OLED_WR_Byte(0xC8,OLED_CMD);//Set COM/Row Scan Direction
    OLED_WR_Byte(0xA6,OLED_CMD);//--set normal display
    OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
    OLED_WR_Byte(0x3f,OLED_CMD);//--1/64 duty
    OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset
    OLED_WR_Byte(0x00,OLED_CMD);//-not offset
    OLED_WR_Byte(0xd5,OLED_CMD);//--set display clock divide ratio/oscillator frequency
    OLED_WR_Byte(0x80,OLED_CMD);//--set divide ratio, Set Clock as 100 Frames/Sec
    OLED_WR_Byte(0xD9,OLED_CMD);//--set pre-charge period
    OLED_WR_Byte(0xF1,OLED_CMD);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
    OLED_WR_Byte(0xDA,OLED_CMD);//--set com pins hardware configuration
    OLED_WR_Byte(0x12,OLED_CMD);
    OLED_WR_Byte(0xDB,OLED_CMD);//--set vcomh
    OLED_WR_Byte(0x40,OLED_CMD);//Set VCOM Deselect Level
    OLED_WR_Byte(0x20,OLED_CMD);//-Set Page Addressing Mode (0x00/0x01/0x02)
    OLED_WR_Byte(0x02,OLED_CMD);//
    OLED_WR_Byte(0x8D,OLED_CMD);//--set Charge Pump enable/disable
    OLED_WR_Byte(0x14,OLED_CMD);//--set(0x10) disable
    OLED_WR_Byte(0xA4,OLED_CMD);// Disable Entire Display On (0xa4/0xa5)
    OLED_WR_Byte(0xA6,OLED_CMD);// Disable Inverse Display On (0xa6/a7)
    OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
    OLED_WR_Byte(0xAF,OLED_CMD); /*display ON*/
    OLED_Clear();
    OLED_Set_Pos(0,0);
SPI 接口OLED屏显示效果
实现图示效果的主程序为:
int main(void)
    uint16_t i=0;
    BOARD_ConfigMPU();
    BOARD_InitPins();
    BOARD_BootClockRUN();
    BOARD_InitDebugConsole();
    GPIO_PinInit(EXAMPLE_LED_GPIO, EXAMPLE_LED_GPIO_PIN, &led_config);
    delay();
    OLED_Init();
    OLED_Clear();
    OLED_ShowString(8,0,"OK1052-C");
    OLED_ShowString(8,2,"OLED TEST");
    OLED_ShowString(8,4,"JINGLIXIXI");
    OLED_ShowString(8,6,"2018/11/8");
    while(1);
刚表态过的朋友 (1 人)
发表评论
引用 liyang 2018-8-29 17:37
您好,您可以尝试使用MCU用户手册中故障处理的故障2提供的方法进行处理
引用 jinglixixi 2018-11-2 23:33
飞凌RT1052开发板例程如何下载?
引用 liyang 2018-11-5 08:35
jinglixixi 发表于 2018-11-2 23:33
飞凌RT1052开发板例程如何下载?
您好,您指的是如何下载教程到您个人电脑还是下载例程到开发板?如果是前者您可以从我们官方论坛的相应版块进行下载。后者的话,我们手册里有教程。
引用 jinglixixi 2018-11-10 09:44
liyang 发表于 2018-11-5 08:35
您好,您指的是如何下载教程到您个人电脑还是下载例程到开发板?如果是前者您可以从我们官方论坛的相应版 ...
谢谢,已经解决了。资料下载在是在社区活动提供的资源中,程序下载是使用的ST_LINK V2。
引用 马驼 2019-2-23 14:47
我也遇到了这个问题,用得也是st-link v2,请问是怎么解决的?
查看全部评论(5)
GMT+8, 2026-9-25 09:49
