问题:335x系列产品烧写Linux时出现NAND erase.chip :device 0 whole chip 之后,不能进行批量烧写和nand
启动 解决办法: 第一步:参考手册中SD烧写卡制作步骤制作一张Win CE的烧写卡 第二步:拨码开关拨到SD卡烧写状态,开机,在终端上会出现文后打印信息,打印到Flash format complete!即可; 以下是打印信息 OEMPlatformInit AM_DEVICE_UART0INFO:OALLogSetZones: dpCurSettings.ulZoneMask: 0x8409 Texas Instruments Windows CE EBOOT for AM33x, Built Jul 30 2015 at 15:24:54 EBOOT Version 0.0.1, BSP BSP_WINCE6_ARM_A8 01.00.00.00 step 0 step 1 step 2 step 3 WSPR IS aaaa WSPR IS 5555 WCLR IS 20 WCLR IS 24 WLDR IS ff8dffff WCRR IS ff8dffff WSPR IS bbbb WSPR IS 4444 TI AM33X ecc type:255 System ready! Preparing for download... INFO: Predownload.... BLSDCardDownload: Filename eboo**.nb0 Init HW: controller RST SDCARD: requested speed 1000000, actual speed 1000000 SDCARD: requested speed 25000000, actual speed 19200000 BLSDCardDownload: Filename xldrnand.nb0 FMD_Init(). FORLINX Embedded Infomation:Incorrect ECC type setting BLReserveBootBlocks(). FMD_Init(). FORLINX Embedded Infomation:Incorrect ECC type setting Checking bootloader blocks are marked as reserved (Num = 30) Skip bad block 11 FMD_Init(). FORLINX Embedded Infomation:Incorrect ECC type setting INFO: Boot configuration found. Boot config Version 3, Signature 1111705159 FMD_Init(). FORLINX Embedded Infomation:Incorrect ECC type setting FMD_Init(). FORLINX Embedded Infomation:Incorrect ECC type setting OS partition does not exist!! Formatting flash... Flash format complete! |
GMT+8, 2026-9-22 17:15
