1201控制单元默认配置的4G模块现已换成了移远EC20,4G部分测试方法有变,现4G测试方法如下: root@freescale /$ lsusb Bus 001 Device 001: ID 1d6b:0002 Bus 002 Device 001: ID 1d6b:0002 Bus 002 Device 002: ID 0424:2514 Bus 002 Device 003: ID 0bda:b720 Bus 002 Device 004: ID 2c7c:0125 //EC20模块 root@freescale /$ cd /bin/ root@freescale /bin$ ./quectel-CM & [1] 2968 [01-01_00:01:10:342] WCDMA [01-01_00:01:10:343] ./quectel-CM profile[1] = (null)/(null)/(null)/0, pincode = (null) [01-01_00:01:10:346] Find /sys/bus/usb/devices/2-1.2 idVendor=2c7c idProduct=0125 [01-01_00:01:10:346] Find /sys/bus/usb/devices/2-1.2:1.4/net/eth1 [01-01_00:01:10:346] Find usbnet_adapter = eth1 [01-01_00:01:10:347] Find /sys/bus/usb/devices/2-1.2:1.4/GobiQMI/qcqmi1 [01-01_00:01:10:347] Find qmichannel = /dev/qcqmi1 [01-01_00:01:10:370] Get clientWDS = 7 root@freescale /bin$ [01-01_00:01:10:402] Get clientDMS = 8 [01-01_00:01:10:434] Get clientNAS = 9 [01-01_00:01:10:466] Get clientUIM = 10 [01-01_00:01:10:498] Get clientWDA = 11 [01-01_00:01:10:530] requestBaseBandVersion EC20CEHCR06A02M1G [01-01_00:01:10:626] requestGetSIMStatus SIMStatus: SIM_READY [01-01_00:01:10:658] requestGetProfile[1] cmnet///0 [01-01_00:01:10:690] requestRegistrationState2 MCC: 460, MNC: 0, PS: Attached, DataCap: LTE [01-01_00:01:10:722] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED [01-01_00:01:10:786] requestRegistrationState2 MCC: 460, MNC: 0, PS: Attached, DataCap: LTE [01-01_00:01:10:818] requestSetupDataCall WdsConnectionIPv4Handle: 0xe17bc750 [01-01_00:01:10:913] requestQueryDataCall IPv4ConnectionStatus: CONNECTED [01-01_00:01:10:945] ifconfig eth1 up [01-01_00:01:10:957] busybox udhcpc -f -n -q -t 5 -i eth1 [01-01_00:01:10:967] udhcpc (v1.20.2) started [01-01_00:01:11:007] Sending discover... [01-01_00:01:11:287] Sending select for 10.1.125.254... [01-01_00:01:11:486] Lease of 10.1.125.254 obtained, lease time 7200 [01-01_00:01:11:510] Deleting routers [01-01_00:01:11:529] adding dns 111.11.1.3 [01-01_00:01:11:529] adding dns 111.11.11.3 root@freescale /bin$ ping baidu.com PING baidu.com (39.156.69.79): 56 data bytes 64 bytes from 39.156.69.79: seq=0 ttl=51 time=100.638 ms 64 bytes from 39.156.69.79: seq=1 ttl=51 time=47.490 ms 64 bytes from 39.156.69.79: seq=2 ttl=51 time=50.264 ms --- baidu.com ping statistics --- 3 packets transmitted, 3 packets received, 0% packet loss |
GMT+8, 2026-9-5 04:46
