OK1028使用systemd工具创建永久网桥
2021-7-20 18:16| 发布者: djh| 查看: 2196| 评论: 0|原作者: djh
类目: 知识库  >  LS1012A/LS1043A/LS1046A系列产品     文档编号: 523
systemd工具创建永久网桥
vi /etc/systemd/network/br0.netdev
填写以下内容:
[NetDev]
Name=br0
Kind=bridge
vi /etc/systemd/network/br0.network
填写以下内容:
[Match]
Name=br0
KernelCommandLine=!root=/dev/nfs
[Network]
Address=172.16.0.1/24
2. 绑定网口到网桥上,这里将swp0、swp1、swp2、swp3加入到br0中。需要分别 创建对应的4个文件。
touch /etc/systemd/network/swp0.network
touch /etc/systemd/network/swp1.network
touch /etc/systemd/network/swp2.network
touch /etc/systemd/network/swp3.network
 每个文件的内容和如下swp0.network内容类似,但是 [Name=swp0] 属性不一样,要和文件名对应。
 swp0.network
[Match]
Name=swp0
[Network]
Bridge=br0
3、将br0设置为静态IP
touch /etc/network/inte**ce.d/br0
auto br0
iface br0  inet static
address 172.16.0.1
4、在脚本中添加重启网络服务命令(红色字体):
 vim lib/systemd/system/ifup@.service
[Unit]
Description=ifup for %I
After=local-fs.target network-pre.target apparmor.service systemd-sysctl.service
Before=network.target shutdown.target network-online.target
BindsTo=sys-subsystem-net-devices-%i.device
After=sys-subsystem-net-devices-%i.device
DefaultDependencies=no
IgnoreOnIsolate=yes
[Service]
# avoid stopping on shutdown via stopping system-ifup.slice
Slice=system.slice
ExecStart=/bin/sh -ec 'ifup --allow=hotplug %I; ifup --allow=auto %I; \
    if ifquery %I >/dev/null; then ifquery --state %I >/dev/null; systemctl restart systemd-networkd.service; fi'
ExecStop=/sbin/ifdown %I
RemainAfterExit=true
TimeoutStartSec=5min
reboot重启
Ifconfig 查看节点:
GMT+8, 2026-9-29 10:01
