2021-9-28 09:46| 发布者: yangy| 查看: 1160| 评论: 0
重新编译烧写镜像后,在文件系统输入以下命令开启连接echo connect > /sys/devices/soc.0/1c13000.udc-controller/udc/1c13000.udc-controller/soft_connect
断开连接echo disconnect > /sys/devices/soc.0/1c13000.udc-controller/udc/1c13000.udc-controller/soft_connect
Atom丶幻梦
npc_x
GMT+8, 2026-10-5 00:15
