A40i Docker文件系统修改后镜像制作
2021-10-29 22:52| 发布者: zhichao| 查看: 2199| 评论: 0
类目:  >  知识库     文档编号: 565
A40idocker系统中想在文件系统安装库文件,可以通过模拟工具修改,这样就可以直接生成镜像
我这里使用的普通用户,多数命令需要加sudo
sudo apt-get install qemu-user-static
进入源码文件系统路径,
例如我的路径是/home/forlinx/Desktop/lichee/buildroot-201611/target/ubuntu16
配置修改
sudo cp /usr/bin/qemu-arm-static usr/bin/
拷贝PC主机端的dns配置,因为待会安装程序时要用网络:
sudo cp -b /etc/resolv.conf  etc/resolv.conf
sudo vim etc/apt/source.list
添加
deb http://ports.ubuntu.com/ubuntu-ports/ xenial main universe
deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial main universe
写脚本
#!/bin/bash
function mnt() {
    echo "MOUNTING"
    sudo mount -t proc /proc ${2}proc
    sudo mount -t sysfs /sys ${2}sys
    sudo mount -o bind /dev ${2}dev
    sudo chroot ${2}
function umnt() {
    echo "UNMOUNTING"
    sudo umount ${2}proc
    sudo umount ${2}sys
    sudo umount ${2}dev
if [ "$1" == "-m" ] && [ -n "$2" ] ;
then
    mnt $1 $2
elif [ "$1" == "-u" ] && [ -n "$2" ];
then
    umnt $1 $2
else
    echo ""
    echo "Either 1'st, 2'nd or both parameters were missing"
    echo ""
    echo "1'st parameter can be one of these: -m(mount) OR -u(umount)"
    echo "2'nd parameter is the full path of rootfs directory(with trailing '/')"
    echo ""
    echo "For example: ch-mount -m /media/sdcard/"
    echo ""
    echo 1st parameter : ${1}
    echo 2nd parameter : ${2}
fi
挂载文件系统
chmod +x ch-mount.sh
sudo ./ch-mount.sh -m 文件系统路径
修改文件系统
退出 exit
取消挂载
sudo ./ch-mount.sh -u 文件系统路径
制作镜像
进入源码路径
lichee文件路径内
sudo ./tools/build/bin/make_ext4fs -l 7168M out/sun8iw11p1/linux/common/rootfs.ext4 buildroot-201611/target/ubuntu16
e2fsck -p out/sun8iw11p1/linux/common/rootfs.ext4
resize2fs -M out/sun8iw11p1/linux/common/rootfs.ext4
不能用编译脚本会有问题
GMT+8, 2026-10-6 16:07
