OK1028单独使用swp0-3网口配置并实现开机显示IP
2022-7-23 17:23| 发布者: hai| 查看: 2979| 评论: 0
类目: 知识库  >  LS1012A/LS1043A/LS1046A系列产品     文档编号: 687
1. 使用system工具创建swp0、swp1、swp2、swp3对应的4个文件:
touch /etc/systemd/network/swp0.network
touch /etc/systemd/network/swp1.network
touch /etc/systemd/network/swp2.network
touch /etc/systemd/network/swp3.network
分别填写以下内容:
[Match]
Name=swp0
KernelCommandLine=!root=/dev/nfs
[Network]
#DHCP=yes
Address=192.168.0.120/24
Gateway=192.168.0.1
[Match]
Name=swp1
[Network]
#DHCP=yes
Address=192.168.1.121/24
Gateway=192.168.1.1
[Match]
Name=swp2
[Network]
#DHCP=yes
Address=192.168.2.122/24
Gateway=192.168.2.1
[Match]
Name=swp3
[Network]
#DHCP=yes
Address=192.168.3.123/24
Gateway=192.168.3.1
每个文件的内容和如下swp0.network内容类似,但是[Name=swp0]属性不一样,要和文件名对应。
2. 在脚本中添加重启网络服务命令(红色字体):
vim /lib/systemd/system/ifup@.service
[Unit]
Description=ifup for %I
After=local-fs.target network-pre.target apparmor.service systemd-sysctl.service
Before=network.target shutdown.target network-online.target
BindsTo=sys-subsystem-net-devices-%i.device
After=sys-subsystem-net-devices-%i.device
DefaultDependencies=no
IgnoreOnIsolate=yes
[Service]
# avoid stopping on shutdown via stopping system-ifup.slice
Slice=system.slice
ExecStart=/bin/sh -ec 'ifup --allow=hotplug %I; ifup --allow=auto %I; \
if ifquery %I >/dev/null; then ifquery --state %I >/dev/null;systemctl restart systemd-networkd.service;fi'
ExecStop=/sbin/ifdown %I
RemainAfterExit=true
TimeoutStartSec=5min
3. 创建swp0、swp1、swp2、swp3对应的4个文件(此步骤是为了不连接网线ifconfig也可看到IP地址)。
touch /etc/network/inte**ces.d/swp0
touch /etc/network/inte**ces.d/swp1
touch /etc/network/inte**ces.d/swp2
touch /etc/network/inte**ces.d/swp3
分别填写以下内容:
auto swp0
iface swp0 inet static
address 192.168.0.120
netmask 255.255.255.0
gateway 192.168.0.1
broadcast 192.168.0.255
auto swp1
iface swp1 inet static
address 192.168.1.121
gateway 192.168.1.1
broadcast 192.168.1.255
auto swp2
iface swp2 inet static
address 192.168.2.122
gateway 192.168.2.1
broadcast 192.168.2.255
auto swp3
iface swp3 inet static
address 192.168.3.123
gateway 192.168.3.1
broadcast 192.168.3.255
4. 创建修改MAC地址脚本:
执行如下命令创建一个脚本文件:
root@forlinx:~#touch mac.sh
root@forlinx:~#vi mac.sh
//写入如下内容
#!/bin/sh
ifconfig swp0 hw ether c2:b6:98:52:c9:c5
ifconfig swp1 hw ether dc:b6:98:52:c9:88
ifconfig swp2 hw ether b2:b6:98:52:46:c4
ifconfig swp3 hw ether e6:02:7f:60:d1:57
修改权限:
root@forlinx:~#chmod 777 mac.sh
创建一个设置mac的服务文件
root@forlinx:~#touch /etc/systemd/system/mac.service
root@forlinx:~#vi /etc/systemd/system/mac.service
//写入如下内容
[Unit]
Description=MAC
After=basic.service X.service thermal-zone-init.service
[Service]
ExecStart=/root/mac.sh
[Install]
WantedBy=multi-user.target
其中Description一行需写入服务名,ExecStart需要写入可执行文件的绝对路径。
保存退出后,在终端上执行如下命令:
root@forlinx:~#systemctl enable /etc/systemd/system/mac.service
Created symlink /etc/systemd/system/multi-user.target.wants/mac.service→/etc/systemd/system/mac.service.
此时即可将新添加的自启动服务生效,重启开发板后,此程序即可自动运行,在命令行 使用ifconfig 命令查看swp0、swp1、swp2、swp3的网卡信息,会发现MAC地址发生了改变
GMT+8, 2026-10-7 00:25
