OKMX8MM-C移植sqlite3库到开发板
2022-7-28 18:06| 发布者: 大别山少年| 查看: 1579| 评论: 0
类目: 知识库  >  i.MX8MM系列产品     文档编号: 699
步骤一:http://www.sqlite.org/download.html 下载Linux版本的源码:
步骤二:创建新建文件夹sqlite
forlinx@ubuntu:~$ mkdir sqlite
forlinx@ubuntu:~$ cd sqlite
步骤三:将下载好的压缩包解压到该目录
forlinx@ubuntu:~/sqlite$ ls
sqlite-autoconf-3390100.tar.gz
forlinx@ubuntu:~/sqlite$ tar -vxf sqlite-autoconf-3390100.tar.gz
sqlite-autoconf-3390100  sqlite-autoconf-3390100.tar.gz
步骤四:新建install文件夹,用于存放后来生产的lib库函数和可执行文件
forlinx@ubuntu:~/sqlite$ cd sqlite-autoconf-3390100
forlinx@ubuntu:~/sqlite/sqlite-autoconf-3390100$ mkdir install
步骤五:进入install目录,获取绝对路径
forlinx@ubuntu:~/sqlite/sqlite-autoconf-3390100$ cd install
forlinx@ubuntu:~/sqlite/sqlite-autoconf-3390100/install$ pwd
/home/forlinx/sqlite/sqlite-autoconf-3390100/install
步骤六:使用configure配置文件
forlinx@ubuntu:~/sqlite/sqlite-autoconf-3390100$ . /opt/fsl-imx-xwayland/4.14-sumo/envir
onment-setup-aarch64-poky-linux
forlinx@ubuntu:~/sqlite/sqlite-autoconf-3390100$ ./configure --prefix=/home/forlinx/sqlite/
sqlite-autoconf-3390100/install --host=arm-linux
--prefix指定源码交叉编译后生成文件的路径,刚才新建的install文件夹
--host指定软件运行环境为arm-linux
步骤七:make 、make install
forlinx@ubuntu:~/sqlite/sqlite-autoconf-3390100$ make
forlinx@ubuntu:~/sqlite/sqlite-autoconf-3390100$ make install
forlinx@ubuntu:~/sqlite/sqlite-autoconf-3390100/install$ ls
bin  include  lib  share
步骤八:拷贝文件到开发板
forlinx@ubuntu:~/sqlite/sqlite-autoconf-3390100/install$ cd bin
forlinx@ubuntu:~/sqlite/sqlite-autoconf-3390100/install/bin$ cp sqlite3 ../lib/
forlinx@ubuntu:~/sqlite/sqlite-autoconf-3390100/install/bin$ cd ../lib/
forlinx@ubuntu:~/sqlite/sqlite-autoconf-3390100/install/lib$ ls
libsqlite3.a  libsqlite3.la  libsqlite3.so  libsqlite3.so.0  libsqlite3.so.0.8.6  pkgconfig  sqlite3
forlinx@ubuntu:~/sqlite/sqlite-autoconf-3390100/install/lib$ tar -zcvf sqlite3.tar.gz libsqlite.so libs
qlite3.so.0  libsqlite3.so.0.8.6  sqlite3
forlinx@ubuntu:~/sqlite/sqlite-autoconf-3390100/install/lib$ cp sqlite.tar.gz /media/forlinx/BOOT/
步骤九:
进入开发板,将压缩包拷贝到开发板并解压,并将libsqlite3.so  libsqlite3.so.0.8.6
libsqlite3.so.0 放到/lib/路径下,将sqlite3 放到/bin/路径下
测试移植成功与否:直接输入sqlite3 即可
GMT+8, 2026-10-4 20:20
