| spi接口是可以修改成can使用的,具体的方法是在内核中修改,具体方法见下: --- a/arch/arm/configs/ok335xs2_evm_linux_defconfig +++ b/arch/arm/configs/ok335xs2_evm_linux_defconfig @@ -725,7 +725,7 @@ CONFIG_CAN_BCM=y CONFIG_CAN_DEV=y CONFIG_CAN_CALC_BITTIMING=y # CONFIG_CAN_TI_HECC is not set -# CONFIG_CAN_MCP251X is not set +CONFIG_CAN_MCP251X=y # CONFIG_CAN_SJA1000 is not set # CONFIG_CAN_C_CAN is not set CONFIG_CAN_D_CAN=y --- a/arch/arm/configs/ok335xs2_evm_linux_sdio_defconfig +++ b/arch/arm/configs/ok335xs2_evm_linux_sdio_defconfig @@ -725,7 +725,7 @@ CONFIG_CAN_BCM=y CONFIG_CAN_DEV=y CONFIG_CAN_CALC_BITTIMING=y # CONFIG_CAN_TI_HECC is not set -# CONFIG_CAN_MCP251X is not set +CONFIG_CAN_MCP251X=y # CONFIG_CAN_SJA1000 is not set # CONFIG_CAN_C_CAN is not set CONFIG_CAN_D_CAN=y --- a/arch/arm/configs/ok335xs2_evm_linux_usb_defconfig +++ b/arch/arm/configs/ok335xs2_evm_linux_usb_defconfig @@ -725,7 +725,7 @@ CONFIG_CAN_BCM=y CONFIG_CAN_DEV=y CONFIG_CAN_CALC_BITTIMING=y # CONFIG_CAN_TI_HECC is not set -# CONFIG_CAN_MCP251X is not set +CONFIG_CAN_MCP251X=y # CONFIG_CAN_SJA1000 is not set # CONFIG_CAN_C_CAN is not set CONFIG_CAN_D_CAN=y --- a/arch/arm/mach-omap2/board-am335xevm.c +++ b/arch/arm/mach-omap2/board-am335xevm.c @@ -81,6 +81,9 @@ #include "control.h" #include <linux/proc_fs.h> +#ifdef CONFIG_CAN_MCP251X +#include <linux/can/platform/mcp251x.h> +#endif /* Convert GPIO signal to GPIO pin number */ #define GPIO_TO_PIN(bank, gpio) (32 * (bank) + (gpio)) @@ -753,6 +756,10 @@ static struct pinmux_config spi0_pin_mux[] = { /* Module pin mux for SPI flash */ static struct pinmux_config spi1_pin_mux[] = { +#if defined(CONFIG_CAN_MCP251X)&&defined(CONFIG_OK335XS2) + {"xdma_event_intr1.gpio0_20",OMAP_MUX_MODE7 | AM33XX_PIN_INPUT | AM33XX_PULL_ENBL| AM33XX_PULL_UP}, + {"xdma_event_intr0.spi1_cs1", OMAP_MUX_MODE4 | AM33XX_PULL_ENBL| AM33XX_PULL_UP | AM33XX_INPUT_EN}, +#endif {"mcasp0_aclkx.spi1_sclk", OMAP_MUX_MODE3 | AM33XX_PULL_ENBL| AM33XX_INPUT_EN}, {"mcasp0_fsx.spi1_d0", OMAP_MUX_MODE3 | AM33XX_PULL_ENBL| AM33XX_PULL_UP | AM33XX_INPUT_EN}, {"mcasp0_axr0.spi1_d1", OMAP_MUX_MODE3 | AM33XX_PULL_ENBL| AM33XX_INPUT_EN}, @@ -2164,7 +2171,28 @@ static struct spi_board_info am335x_spi0_slave_info[] = { }, }; +#ifdef CONFIG_CAN_MCP251X +#define AM335XEVM_MCP2515_IRQ_GPIO GPIO_TO_PIN(0, 20) + +static struct mcp251x_platform_data mcp251x_info={ + .oscillator_frequency = 8000000, + .transceiver_enable = NULL, + .power_enable = NULL, +}; +#endif + static struct spi_board_info am335x_spi1_slave_info[] = { +#ifdef CONFIG_CAN_MCP251X + { + .modalias = "mcp2515", /* device node name */ + .platform_data=&mcp251x_info, + .max_speed_hz = 10000000, + .bus_num = 2, + .chip_select = 1, + .mode = SPI_MODE_0, /* CPOL=0, CPHA=0 */ + .irq = OMAP_GPIO_IRQ(AM335XEVM_MCP2515_IRQ_GPIO), + } +#else { .modalias = "spidev", .max_speed_hz = 48000000,//48Mbps @@ -2172,6 +2200,7 @@ static struct spi_board_info am335x_spi1_slave_info[] = { .chip_select = 0, .mode = SPI_MODE_1, }, +#endif }; static struct gpmc_timings am335x_nand_timings = { diff --git a/drivers/spi/spi-omap2-mcspi.c b/drivers/spi/spi-omap2-mcspi.c index 94c438d..6db474d 100644 --- a/drivers/spi/spi-omap2-mcspi.c +++ b/drivers/spi/spi-omap2-mcspi.c @@ -241,6 +241,12 @@ static void omap2_mcspi_set_master_mode(struct spi_master *master) /* setup when switching from (reset default) slave mode * to single-channel master mode */ + /****/ + l = mcspi_read_reg(master,OMAP2_MCSPI_SYST); + l |= (1 << 9); + l &= ~(1 << 8); + mcspi_write_reg(master,OMAP2_MCSPI_SYST,l); + /***/ l = mcspi_read_reg(master, OMAP2_MCSPI_MODULCTRL); MOD_REG_BIT(l, OMAP2_MCSPI_MODULCTRL_STEST, 0); MOD_REG_BIT(l, OMAP2_MCSPI_MODULCTRL_MS, 0); @@ -680,8 +686,10 @@ static int omap2_mcspi_setup_transfer(struct spi_device *spi, /* standard 4-wire master mode: SCK, MOSI/out, MISO/in, nCS * REVISIT: this controller could support SPI_3WIRE mode. */ - l &= ~(OMAP2_MCSPI_CHCONF_IS|OMAP2_MCSPI_CHCONF_DPE1); - l |= OMAP2_MCSPI_CHCONF_DPE0; +// l &= ~(OMAP2_MCSPI_CHCONF_IS|OMAP2_MCSPI_CHCONF_DPE1); +// l |= OMAP2_MCSPI_CHCONF_DPE0; + l |= (OMAP2_MCSPI_CHCONF_IS|OMAP2_MCSPI_CHCONF_DPE1); + l &= ~OMAP2_MCSPI_CHCONF_DPE0; /* wordlength */ l &= ~OMAP2_MCSPI_CHCONF_WL_MASK; diff --git a/version b/version new file mode 100644 index 0000000..542723a --- /dev/null +++ b/version @@ -0,0 +1,2 @@ +2014-12-29 +Merge kernel patch to fix ubifs bug --- a/drivers/spi/spi-omap2-mcspi.c +++ b/drivers/spi/spi-omap2-mcspi.c @@ -241,6 +241,12 @@ static void omap2_mcspi_set_master_mode(struct spi_master *master) /* setup when switching from (reset default) slave mode * to single-channel master mode */ + /****/ + l = mcspi_read_reg(master,OMAP2_MCSPI_SYST); + l |= (1 << 9); + l &= ~(1 << 8); + mcspi_write_reg(master,OMAP2_MCSPI_SYST,l); + /***/ l = mcspi_read_reg(master, OMAP2_MCSPI_MODULCTRL); MOD_REG_BIT(l, OMAP2_MCSPI_MODULCTRL_STEST, 0); MOD_REG_BIT(l, OMAP2_MCSPI_MODULCTRL_MS, 0); @@ -680,8 +686,10 @@ static int omap2_mcspi_setup_transfer(struct spi_device *spi, /* standard 4-wire master mode: SCK, MOSI/out, MISO/in, nCS * REVISIT: this controller could support SPI_3WIRE mode. */ - l &= ~(OMAP2_MCSPI_CHCONF_IS|OMAP2_MCSPI_CHCONF_DPE1); - l |= OMAP2_MCSPI_CHCONF_DPE0; +// l &= ~(OMAP2_MCSPI_CHCONF_IS|OMAP2_MCSPI_CHCONF_DPE1); +// l |= OMAP2_MCSPI_CHCONF_DPE0; + l |= (OMAP2_MCSPI_CHCONF_IS|OMAP2_MCSPI_CHCONF_DPE1); + l &= ~OMAP2_MCSPI_CHCONF_DPE0; /* wordlength */ l &= ~OMAP2_MCSPI_CHCONF_WL_MASK; |
GMT+8, 2026-9-22 21:10
