6254 GPIOCHIP号不对的问题
2023-3-28 09:18| 发布者: ljb2019001| 查看: 584| 评论: 0
类目: AM6254系列产品  >  linux     文档编号: 959
现象如下,gpiochip1对应的gpio0有92个引脚,但是488-402=86,只有87个引脚
root@ok6254:~# cat /sys/kernel/debug/gpio
gpiochip2: GPIOs 314-401, parent: platform/601000.gpio, 601000.gpio:
 gpio-330 (                    |led1                ) out lo
 gpio-331 (                    |led2                ) out lo
 gpio-332 (                    |led3                ) out lo
 gpio-333 (                    |led4                ) out lo
 gpio-336 (                    |fixed-regulator-rgb ) out lo
gpiochip1: GPIOs 402-488, parent: platform/600000.gpio, 600000.gpio:
 gpio-433 (                    |net-5g-rst          ) out lo ACTIVE LOW
 gpio-437 (                    |phy_rstn            ) out lo
 gpio-438 (                    |id                  ) in  lo
 gpio-440 (                    |RT9186              ) out lo
 gpio-441 (                    |fixed-regulator-lvds) out lo
 gpio-442 (                    |phy_rstn            ) out lo
 gpio-444 (                    |heartbeat           ) out lo
 gpio-473 (                    |regulator-6         ) out lo
gpiochip0: GPIOs 489-511, parent: platform/4201000.gpio, 4201000.gpio:
root@ok6254:~#
通过搜索打印信息定位代码,发现OK6254-linux-kernel/drivers/gpio/gpiolib.c中相关内容
seq_printf(s, "%s%s: GPIOs %d-%d", (char *)s->private,
                   dev_name(&gdev->dev),
                   gdev->base, gdev->base + gdev->ngpio - 1);
而这个ngpio是通过设备配置的,如下
main_gpio0: gpio@600000 {
compatible = "ti,am64-gpio", "ti,keystone-gpio";
reg = <0x0 0x00600000 0x0 0x100>;
gpio-controller;
#gpio-cells = <2>;
interrupt-parent = <&main_gpio_intr>;
interrupts = <190>, <191>, <192>,
     <193>, <194>, <195>;
interrupt-controller;
#interrupt-cells = <2>;
ti,ngpio = <87>;
ti,davinci-gpio-unbanked = <0>;
power-domains = <&k3_pds 77 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 77 0>;
clock-names = "gpio";
所以修改方法就是把ti,ngpio = <87>;修改为ti,ngpio = <92>;
同理其他两组gpio也是不对的
GMT+8, 2026-10-2 21:43
