G2L命令行显示中文(Linux4.19.165)
2023-7-31 13:32| 发布者: xing星| 查看: 240| 评论: 0
类目:  >  知识库     文档编号: 1073
修改内核配置
路径OKG2L-linux-sdk10里面加载环境变量. environment-setup-aarch64-smarc-rzg2l-toolchain
进入OKG2L-linux-kernel中执行make menuconfig ARCH=arm64
做以下修改
  • File systems---> DOS/FAT/NT Filesystems --->Default codepage for FAT
    改为 936
  • File systems---> DOS/FAT/NT Filesystems ---> Default iocharset for FAT
    改为 utf8
  • File systems--->Native language support --->Simplified Chinese charset (CP936, GB2312)
    选为星号
  • File systems--->Native language support --->NLS UTF-8
    选为星号
  • File systems--->Native language support --->Default NLS Option
    改为utf8
重新编译内核
编译出来的内核镜像在OKG2L-linux-sdk10/images/kernel/Image
参照使用手册重新烧写内核镜像到开发板,或者直接将Image替换到开发板的/boot文件夹中
busybox配置
busybox位置:OKG2L-linux-sdk/tools/third**/busybox-1.34.1.tar.bz2
sdk中解压这个,进去执行make menuconfig
  • Settings---> Don't use /usr
    选择为星号
  • Settings---> Cross compiler prefix
    填入aarch64-poky-linux-
  • Settings---> Path to sysroot
    填入/opt/poky/3.1.5/sysroots/aarch64-poky-linux/
  • Settings--->Enable locale support (system needs locale for this to work)
    选择为星号
  • Settings--->Support Unicode
    选择为星号
  • Settings--->Character code to substitute unprintable characters with
    修改为65533
  • Settings--->Range of supported Unicode characters
    修改为195102
修改./libbb/printable_string.c注释掉0x7f
                if (c < ' ')
                       break;
//             if (c >= 0x7f)
//                     break;
               s++;
#if ENABLE_UNICODE_SUPPORT
       dst = unicode_conv_to_printable(stats, str);
#else
               char *d = dst = xstrdup(str);
               while (1) {
                       unsigned char c = *d;
                       if (c == '\0')
                               break;
                       if (c < ' ' /*|| c >= 0x7f*/)
                               *d = '?';
                       d++;
修改./libbb/unicode.c注释掉0x7f
static char* FAST_FUNC unicode_conv_to_printable2(uni_stat_t *stats, const char *src, unsigned width, int flags)
       char *dst;
       unsigned dst_len;
       unsigned uni_count;
       unsigned uni_width;
       if (unicode_status != UNICODE_ON) {
               char *d;
               if (flags & UNI_FLAG_PAD) {
                       d = dst = xmalloc(width + 1);
                       while ((int)--width >= 0) {
                               unsigned char c = *src;
                               if (c == '\0') {
                                       do
                                               *d++ = ' ';
                                       while ((int)--width >= 0);
                                       break;
                               *d++ = (c >= ' '/* && c < 0x7f*/) ? c : '?';
                               src++;
                       *d = '\0';
              } else {
                       d = dst = xstrndup(src, width);
                       while (*d) {
                               if (c < ' '/* || c >= 0x7f*/)
                                       *d = '?';
                               d++;
参照编译手册配置交叉工具编译链environment-setup-aarch64-poky-linux
执行
make –j8
make install
./_install/bin/busybox复制出来,后面替换到开发板的/usr/bin下面
执行ln -sf /usr/bin/busybox /usr/bin/ls
sync之后,reboot重新启动,ls就可以正常显示中文了
测试情况中文.txt
root@okg2l:/run/media/sda1/test/chinese test/Chinese_test# ls
显示中文     显示中文.txt
GMT+8, 2026-9-12 15:52
