9352适配spi转can-mcp2518芯片
2023-11-30 17:43| 发布者: 奥卡姆剃刀| 查看: 1052| 评论: 0
类目:  >  知识库     文档编号: 1228
MCP2518这个芯片包含can以及canfd功能,相比于mcp2517芯片来说,新增了ECC校验功能,保障了传输过程的稳定性。
说明:OKMX93开发板内核源码中已经包含了2518的驱动,直接修改设备树及驱动配置即可。
驱动路径:OKMX93-linux-sdk/OKMX93-linux-kernel/drivers/net/can/spi/mcp251xfd-core.c
1添加驱动配置
Make menuconfig打开图形配置界面,搜索“MCP251XFD
将这一行选成编译成模块:
(M) Microchip MCP251xFD SPI CAN controllers
2修改设备树
forlinx@ubuntu:~/OKMX93-linux-sdk/OKMX93-linux-kernel/$ vi arch/arm64/boot/dts/freescale/\
OK-MX93-C.dts
3添加时钟节点:
clk20M: oscillator-0 {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <20000000>;
新增lpspi3节点,在此节点下增加mcp2518节点:
&lpspi3 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_lpspi3>;
pinctrl-1 = <&pinctrl_lpspi3>;
cs-gpios = <&gpio2 8 GPIO_ACTIVE_LOW>;
status = "okay";
spican:can@0 {
compatible = "microchip,mcp2518fd";
reg = <0>;
clocks = <&clk20M>;                      //使用刚刚写的时钟
spi-max-frequency = <10000000>;  //spi最大频率设置,此处为1MHz
interrupts-extended = <&gpio2 16 IRQ_TYPE_LEVEL_LOW>;//中断引脚配置,中断引脚是GPIO2_IO16
/*interrupt-parent = <&gpio2>;
interrupts = <16 IRQ_TYPE_LEVEL_LOW>;*/
/*vdd-supply = <&vdc_5v>;
xceiver-supply = <&vdc_5v>;*/
/*status = "okay";*/
5添加中断引脚配置:
pinctrl_inte:mcp2518fdrp{
fsl,pins = <
MX93_PAD_GPIO_IO16__GPIO2_IO16 0x31e
6编译源码并烧写。
7开机验证
在开发板上SPI3接口处接上2518转接板,启动开发板。
查看驱动是否成功挂载:
root@ok-mx93:~# lsmod
Module Size Used by
can_raw 20480 1
can 28672 1 can_raw
vvcam_video 32768 0
moal 716800 1
mlan 499712 1 moal
cdc_acm 32768 0
xr_usb_serial_common 45056 0
vvcam_isp 69632 1
vvcam_dwe 20480 1
imx8_media_dev 20480 0
basler_camera_driver 16384 0
crct10dif_ce 16384 1
edt_ft5x06 24576 0
basler_camera_driver_vvcam 16384 0
goodix 24576 0
mcp251xfd 24576 0
flexcan 32768 0
can_dev 36864 2 mcp251x,flexcan
8查看是否生成节点:
root@ok-mx93:~# ifconfig can2
can2 Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP  MTU:16  Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:10
RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
Interrupt:32
GMT+8, 2026-9-25 01:06
