T507+Android10更换桌面默认壁纸
2024-1-17 15:19| 发布者: 香飘飘~~~| 查看: 473| 评论: 0
类目: T507系列产品  >  Android     文档编号: 1269
准备壁纸图片
android/frameworks/base/core/res/res/drawable-nodpi/
android/frameworks/base/core/res/res/drawable-sw600dp-nodpi/
android/frameworks/base/core/res/res/drawable-sw720dp-nodpi/
修改Wall**Manager.java
android/frameworks/base/core/java/android/app/Wall**Manager.java
diff --git a/core/java/android/app/Wall**Manager.java b/core/java/android/app/Wall**Manager.java
index 325a54bf..67be96b6 100644
--- a/core/java/android/app/Wall**Manager.java
+++ b/core/java/android/app/Wall**Manager.java
@@ -1874,7 +1874,8 @@ public class Wall**Manager {
return null;
} else {
whichProp = PROP_WALL**;
- defaultResId = com.android.internal.R.drawable.default_wall**;
+ //defaultResId = com.android.internal.R.drawable.default_wall**;
+ defaultResId = com.android.internal.R.drawable.sbc1308_wall**;
final String path = SystemProperties.get(whichProp);
if (!TextUtils.isEmpty(path)) {
按照手册重新编译烧写镜像
GMT+8, 2026-9-10 15:06
