A40i-linux5.10-支持usb虚拟网卡
2024-7-31 10:23| 发布者: yhj_nb| 查看: 486| 评论: 0
类目: 知识库  >  A40i/T3系列产品     文档编号: 1472
一、加载内核驱动
进入图形化配置界面
forlinx@ubuntu:~/work/OKA40i-linux-sdk$ ./build.sh menuconfig
按如下配置
Device Drivers --->
[ * ] USB support --->
<*> USB Gadget Support --->
[ * ]  Ethernet Control Model (CDC ECM)
[ * ]  RNDIS
Device Drivers --->
USB Gadget precomposed configurations --->
<M> Ethernet Gadget (with CDC Ethernet support)
[ * ] RNDIS support
修改完后执行
forlinx@ubuntu:~/work/OKA40i-linux-sdk$ ./build.sh saveconfig
二、修改驱动
如下为修改patch:
OKA40i-linux-sdk/kernel
diff --git a/linux-5.10/drivers/usb/gadget/function/u_ether.c b/linux-5.10/drivers/usb/gadget/function/u_ether.c
old mode 100644
new mode 100755
index 64ef97ab9..45590e3ef
--- a/linux-5.10/drivers/usb/gadget/function/u_ether.c
+++ b/linux-5.10/drivers/usb/gadget/function/u_ether.c
@@ -218,7 +218,11 @@ rx_submit(struct eth_dev *dev, struct usb_request *req, gfp_t gfp_flags)
                size = max_t(size_t, size, dev->port_usb->fixed_out_len);
        spin_unlock_irqrestore(&dev->lock, flags);
-       skb = __netdev_alloc_skb(dev->net, size + NET_IP_ALIGN, gfp_flags);
+       #ifdef CONFIG_USB_SUNXI_UDC0
+               skb = netdev_alloc_skb_ip_align((struct net_device *)dev, size);
+       #else
+               skb = __netdev_alloc_skb((struct net_device *)dev, size + NET_IP_ALIGN, gfp_flags);
+       #endif
        if (skb == NULL) {
                DBG(dev, "no rx skb\n");
                goto enomem;
OKA40i-linux-sdk/bsp
diff --git a/drivers/usb/sunxi_usb/udc/sunxi_udc.c b/drivers/usb/sunxi_usb/udc/sunxi_udc.c
old mode 100644
new mode 100755
index 4972dbb..1402213
--- a/drivers/usb/sunxi_usb/udc/sunxi_udc.c
+++ b/drivers/usb/sunxi_usb/udc/sunxi_udc.c
@@ -2620,6 +2620,7 @@ static int sunxi_udc_queue(struct usb_ep *_ep,
        struct sunxi_udc *dev = NULL;
        unsigned long flags = 0;
        u8 old_ep_index = 0;
+       int ret;
        if (_ep == NULL || _req == NULL) {
                DMSG_PANIC("ERR: invalid argment\n");
@@ -2650,13 +2651,18 @@ static int sunxi_udc_queue(struct usb_ep *_ep,
                return -EINVAL;
-       sunxi_udc_handle_unaligned_buf_start(ep, req);
+       //sunxi_udc_handle_unaligned_buf_start(ep, req);
        spin_lock_irqsave(&ep->dev->lock, flags);
        _req->status = -EINPROGRESS;
        _req->actual = 0;
        if (is_sunxi_udc_dma_capable(req, ep)) {
                spin_unlock_irqrestore(&ep->dev->lock, flags);
+               ret = sunxi_udc_handle_unaligned_buf_start(ep, req);
+               if (ret)
+                      return ret;
                sunxi_udc_map_dma_buffer(req, dev, ep);
三、其他修改
取消adb服务开机自启,有两种操作方式:
1. 开发板里操作
删除 /etc/init.d/S50adb_start 文件或者将其重命名为bak-S50adb_start
2. 源码里操作(改完后再编译)
删除 OKA40i-linux-sdk/out/a40i_h/OKA40i-C/buildroot/buildroot/target/etc/init.d/S50adb_start 文件或者将其重命名为bak-S50adb_start
四、使用方式
做完上述修改后,执行全编译,然后打包生成新镜像
在开发板中加载对应模块
[root@Tina5 ~]# insmod /lib/modules/5.10.149/g_ether.ko
之后可以看到对应的usb0网卡
然后在windows端识别为了网络模块
GMT+8, 2026-9-18 00:09
