解决6254使用ec20,偶发性无法注册wwan0节点的问题
2024-9-30 14:13| 发布者: 87岁拄拐上分| 查看: 322| 评论: 0
类目: AM6254系列产品  >  linux     文档编号: 1548
使用 GobiNet or QMI WWAN,需要阻止第四个接口注册为串口。
kernel/drivers/usb/serial/option.c
 * Allow matching on bNumEndpoints for devices whose inte**ce numbers
 * can change (e.g. Quectel EP06).
if (device_flags & NUMEP2 && iface_desc->bNumEndpoints != 2)
return -ENODEV;
#if 1  //Added by Sky
//Quectel UC20's inte**ce 4 can be used as USB Network device
if (serial->dev->descriptor.idVendor == cpu_to_le16(0x05C6) && serial->dev->descriptor.idProduct == cpu_to_le16(0x9003)  \
 && serial->inte**ce->cur_altsetting->desc.bInte**ceNumber >= 4)
return -ENODEV;
//Quectel EC20's inte**ce 4 can be used as USB Network device
if (serial->dev->descriptor.idVendor == cpu_to_le16(0x05C6) && serial->dev->descriptor.idProduct == cpu_to_le16(0x9215)  \
return -ENODEV;
//Quectel EC21&EC25&EC20 R2.0's inte**ce 4 can be used as USB Network device
if (serial->dev->descriptor.idVendor == cpu_to_le16(0x2C7C)   \
return -ENODEV;
#endif
/* Store the device flags so we can use them during attach. */
usb_set_serial_data(serial, (void *)device_flags);
GMT+8, 2026-9-15 10:43
