3588的typec1转usb_host使用2 、3lane做usb3
2024-9-30 16:57| 发布者: xing星| 查看: 1004| 评论: 0
类目: RK3588系列产品  >  Linux     文档编号: 1550
在按照typec转host的修改方法,将typec作为host使用时,如果使用的是2、3lane作为usb3,如下配置;
其中rockchip,dp-lane-mux = <0 1>;行表示dp用0 1lane,这样usb3就会使用2、3lane,但是注意,此时相应的dp接口是需要打开的,不然usb3仍然会落在0、1lane上;如typec1的话,需要在uboot选屏界面将dp1接口选上,这样usb3的信号就会落在2、3lane上。
diff --git a/arch/arm64/boot/dts/rockchip/OK3588-C-common.dtsi b/arch/arm64/boot/dts/rockchip/OK3588-C-common.dtsi
index f13ce47c6..a3eaffe60 100644
--- a/arch/arm64/boot/dts/rockchip/OK3588-C-common.dtsi
+++ b/arch/arm64/boot/dts/rockchip/OK3588-C-common.dtsi
@@ -846,71 +846,6 @@
              status = "okay";
-       usbc1: fusb302@22 {
-               compatible = "fcs,fusb302";
-               reg = <0x22>;
-               interrupt-parent = <&gpio1>;
-               interrupts = <RK_PB3 IRQ_TYPE_LEVEL_LOW>;
-               pinctrl-names = "default";
-               pinctrl-0 = <&usbc1_int>;
-               vbus-supply = <&vbus5v0_typec1>;
-               status = "okay";
-               ports {
-                       #address-cells = <1>;
-                       #size-cells = <0>;
-                       port@0 {
-                               reg = <0>;
-                               usbc1_role_sw: endpoint@0 {
-                                       remote-endpoint = <&dwc3_1_role_switch>;
-               usb_con1: connector {
-                       compatible = "usb-c-connector";
-                       label = "USB-C";
-                       data-role = "dual";
-                       power-role = "dual";
-                       try-power-role = "sink";
-                       op-sink-microwatt = <1000000>;
-                       sink-pdos =
-                               <PDO_FIXED(5000, 1000, PDO_FIXED_USB_COMM)>;
-                       source-pdos =
-                               <PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM)>;
-                       altmodes {
-                               altmode@0 {
-                                       reg = <0>;
-                                       svid = <0xff01>;
-                                       vdo = <0xffffffff>;
-                       ports {
-                               port@0 {
-                                       reg = <0>;
-                                       usbc1_orien_sw: endpoint {
-                                               remote-endpoint = <&usbdp_phy1_orientation_switch>;
-                               port@1 {
-                                       reg = <1>;
-                                       dp1_altmode_mux: endpoint {
-                                               remote-endpoint = <&usbdp_phy1_dp_altmode_mux>;
&i2c7 {
@@ -1260,8 +1195,8 @@
&u2phy1_otg {
-       phy-supply = <&vcc5v0_sys>;
      status = "okay";
+       phy-supply = <&vbus5v0_typec1>;
&u2phy2_host {
@@ -1339,25 +1274,7 @@
&usbdp_phy1 {
      status = "okay";
-       orientation-switch;
-       rockchip,dp-lane-mux = <2 3>;
-       svid = <0xff01>;
-       sbu1-dc-gpios = <&gpio4 RK_PA1 GPIO_ACTIVE_HIGH>;
-       sbu2-dc-gpios = <&gpio4 RK_PA2 GPIO_ACTIVE_HIGH>;
-       port {
-               usbdp_phy1_orientation_switch: endpoint@0 {
-                       reg = <0>;
-                       remote-endpoint = <&usbc1_orien_sw>;
-               usbdp_phy1_dp_altmode_mux: endpoint@1 {
-                       reg = <1>;
-                       remote-endpoint = <&dp1_altmode_mux>;
+       rockchip,dp-lane-mux = <0 1>;
&usbdp_phy1_dp {
@@ -1374,16 +1291,7 @@
&usbdrd_dwc3_1 {
      status = "okay";
-       dr_mode = "otg";
-       usb-role-switch;
-       port {
-               dwc3_1_role_switch: endpoint@0 {
-                       reg = <0>;
-                       remote-endpoint = <&usbc1_role_sw>;
+       dr_mode = "host";
&usbhost3_0 {
刚表态过的朋友 (2 人)
GMT+8, 2026-9-27 03:32
