修改分区大小,将根分区改为2G,需要修改三个文件: lichee/tools/pack/chips/sun8iw11p1/configs/default/sys_partition_linux.fex 注:将usr分区减小,添加到rootfs分区中 lichee/tools/pack/chips/sun8iw11p1/usr-resource/usr-resource.ini lichee/out/sun8iw11p1/linux/common/buildroot/.config 执行编译打包指令,重新烧写镜像 |
GMT+8, 2026-9-21 08:00
