USB触摸去除鼠标指针
2022-8-3 11:14| 发布者: Q_Y_X| 查看: 951| 评论: 0
类目: i.MX8MP系列产品  >  Linux     文档编号: 715
说明:部分usb触摸会被识别为触摸和鼠标两个设备,在不插入鼠标得情况下,桌面上还会出现一个鼠标指针,影响显示效果,需要将其去掉。
首先通过如下命令读取被识别为鼠标事件的设备名:
root@OK8MP:~# cat /proc/bus/input/devices
I: Bus=0019 Vendor=0000 Product=0000 Version=0000
N: Name="30370000.snvs:snvs-powerkey"
P: Phys=snvs-pwrkey/input0
S: Sysfs=/devices/platform/soc@0/30000000.bus/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
U: Uniq=
H: Handlers=kbd event0
B: PROP=0
B: EV=3
B: KEY=10000000000000 0
I: Bus=0000 Vendor=0000 Product=0000 Version=0000
N: Name="audio-hdmi HDMI Jack"
P: Phys=ALSA
S: Sysfs=/devices/platform/sound-hdmi/sound/card3/input2
U: Uniq=
H: Handlers=event1
B: PROP=0
B: EV=21
B: SW=40
I: Bus=0019 Vendor=0001 Product=0001 Version=0100
N: Name="keys"
P: Phys=gpio-keys/input0
S: Sysfs=/devices/platform/keys/input/input3
U: Uniq=
H: Handlers=kbd event2
B: PROP=0
B: EV=3
B: KEY=108000000000 0
I: Bus=0003 Vendor=222a Product=0001 Version=0110
N: Name="ILITEK ILITEK-TP Touchscreen"      //触摸设备名
P: Phys=usb-xhci-hcd.0.auto-1.3/input0
S: Sysfs=/devices/platform/32f10108.usb/38200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:222A:0001.0001/input/input4
U: Uniq=
H: Handlers=event3
B: PROP=0
B: EV=1b
B: KEY=400 0 0 0 0 0
B: ABS=10000000003
B: MSC=10
N: Name="ILITEK ILITEK-TP Mouse"           //被识别为鼠标的设备名
S: Sysfs=/devices/platform/32f10108.usb/38200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:222A:0001.0001/input/input6
U: Uniq=
H: Handlers=event4
B: PROP=0
B: EV=1b
B: KEY=1f0000 0 0 0 0
B: ABS=3
B: MSC=10
在知道被识别为鼠标事件的设备名为ILITEK ILITEK-TP Mouse之后,在/home/forlinx/work/OK8MP-linux-sdk/OK8MP-linux-kernel/drivers/input/evdev.c该驱动源码中添加下图中的内容:
说明:strncmp为对比函数,将包含该名称中关键字的事件过滤掉,该函数的使用方法在如下链接中可以进行了解,
https://jingyan.baidu.com/article/636f38bb5cb6e897b9461042.html
修改驱动源码后将源码编译进内核并更新镜像:
forlinx@ubuntu:~/work/OK8MP-linux-sdk$ . /opt/fsl-imx-xwayland/5.4-zeus/environment-setu\
p-aarch64-poky-linux
forlinx@ubuntu:~/work/OK8MP-linux-sdk$ . environment-setup-aarch64-poky-linux
forlinx@ubuntu:~/work/OK8MP-linux-sdk$ ./build.sh kernel
系统启动后,将待替换设备树放于U盘中,插入到开发板上,在超级终端输入命令:
root@OK8MP:~# cd /run/media/mmcblk2p1/
root@OK8MP:/run/media/mmcblk2p1# ls
U盘中的新镜像替换掉原来的镜像
root@OK8MP:/run/media/mmcblk2p1# cp /run/media/sda1/OK8MP-C.dtb ./
//替换设备树,此处U盘路径/run/media/sda1路径为例
root@OK8MP:/run/media/mmcblk2p1# cp /run/media/sda1/Image ./            //替换Image
root@OK8MP:/run/media/mmcblk2p1# sync                           //一定要记得保存!!!
root@OK8MP:/run/media/mmcblk2p1# reboot                               //或者硬件reset
重启后成功替换新的镜像,鼠标箭头就可以去除了。
GMT+8, 2026-9-14 00:32
