6254关于M核的引脚在A核使用
2022-9-1 15:15| 发布者: ljb2019001| 查看: 841| 评论: 0
类目: AM6254系列产品  >  linux     文档编号: 746
设备树配置
&mcu_pmx0 {
        mymcugpio1_pins_default: mymcugpio1-pins-default {
                pinctrl-single,pins = <
                        AM62X_MCU_IOPAD(0x004, PIN_INPUT, 7)
&mcu_gpio0 {
        pinctrl-names = "default";
pinctrl-0 =<&mymcugpio1_pins_default>;
        status = "okay";
使用gpio-leds驱动的配置,在leds节点中添加如下
--- a/arch/arm64/boot/dts/ti/OK6254-C.dts
+++ b/arch/arm64/boot/dts/ti/OK6254-C.dts
@@ -166,7 +166,7 @@
                compatible = "gpio-leds";
                pinctrl-0 = <&usr_led_pins_default>;
+               pinctrl-1 = <&mymcugpio1_pins_default>;
                led-0 {
                        label = "heartbeat";
                        gpios = <&main_gpio0 42 GPIO_ACTIVE_HIGH>;
@@ -206,6 +206,14 @@
                        led-pattern = <500 500>;
                        default-state = "on";
+               led-5 {
+                       label = "led5";
+                        gpios = <&mcu_gpio0 1 GPIO_ACTIVE_HIGH>;
+                        linux,default-trigger = "timer";
+                        led-pattern = <500 500>;
+                        default-state = "on";
GMT+8, 2026-9-26 14:55
