am6254新建emmc分区
2022-10-31 14:27| 发布者: 这是啥啊| 查看: 148| 评论: 0
类目:  >  知识库     文档编号: 808
1.修改Ramdisk文件夹中的update.sh:
/sbin/fdisk /dev/mmcblk0 << EOF
d
n
p
w
EOF
为:
d
n
p
14897471
w
EOF
注:其中172416为起始sector14897471为结束sector,当输入回车时,是默认值(最大值)。
2.编译后把ramdisk.img.gz放到烧写sd卡中进行烧写。
3.烧录完成,启动系统,用fdisk重新分区
root@ok6254:~# fdisk /dev/mmcblk0
Command (m for help): n
Partition type
   p   primary (2 primary, 0 extended, 2 free)
   e   extended (container for logical partitions)
Select (default p): p
Partition number (3,4, default 3): 3
First sector (14897472-15269887, default 14899200): (回车)
Last sector, +/-sectors or +/-size{K,M,G,T,P} (14899200-15269887, default 15269887): (回车)
Created a new partition 3 of type 'Linux' and of size 181 MiB.
Command (m for help): w
The partition table has been altered.
Syncing disks.
root@ok6254:~# mkfs.ext4 /dev/mmcblk0p3
mke2fs 1.45.7 (28-Jan-2021)
Discarding device blocks: done
Creating filesystem with 185344 1k blocks and 46368 inodes
Filesystem UUID: 022088fc-b884-456b-af55-f601fbd15a7f
Superblock backups stored on blocks:
8193, 24577, 40961, 57345, 73729
Allocating group tables: done
Writing inode tables: done
Creating journal (4096 blocks): done
Writing superblocks and filesystem accounting information: done
root@ok6254:~# mkdir /run/media/mmcblk0p3/
root@ok6254:~# mount /dev/mmcblk0p3 /run/media/mmcblk0p3
GMT+8, 2026-4-4 04:10
