6254新增uart串口
2022-11-30 16:25| 发布者: 这是啥啊| 查看: 504| 评论: 0
类目:  >  知识库     文档编号: 837
新增uart4
设备树修改:
main_uart1_pins_default: main-uart1-pins-default {
pinctrl-single,pins = <
AM62X_IOPAD(0x1ac, PIN_INPUT, 2) /* (E19) MCASP0_AFSR.UART1_RXD */
AM62X_IOPAD(0x1b0, PIN_OUTPUT, 2) /* (A20) MCASP0_ACLKR.UART1_TXD */
main_uart4_pins_default: main-uart4-pins-default {
AM62X_IOPAD(0x70, PIN_OUTPUT, 2) /* (T24) UART4_TXD */
AM62X_IOPAD(0x6c, PIN_INPUT, 2) /* (T22) UART4_RXD */
main_uart5_pins_default: main-uart5-pins-default {
AM62X_IOPAD(0x08, PIN_INPUT, 5) /* (J24) OSPI0_DQS.UART5_CTSn */
AM62X_IOPAD(0x04, PIN_OUTPUT, 5) /* (G25) OSPI0_LBCLKO.UART5_RTSn */
AM62X_IOPAD(0x34, PIN_INPUT, 5) /* (H21) OSPI0_CSn2.UART5_RXD */
AM62X_IOPAD(0x38, PIN_OUTPUT, 5) /* (E24) OSPI0_CSn3.UART5_TXD */
&main_uart3 {
status = "disabled";
&main_uart4 {
pinctrl-names = "default";
pinctrl-0 = <&main_uart4_pins_default>;
/* Main UART1 is used by TIFS firmware */
status = "okay";
&main_uart5 {
pinctrl-0 = <&main_uart5_pins_default>;
status = "okay";
重新编译内核生成设备树,放到开发板的boot目录下,重启更新设备树。生成的设备节点是ttyS6
GMT+8, 2026-4-3 14:23
