A40i fex文件引脚配置和设备数引脚配置
2022-12-28 16:58| 发布者: 会飞的大灰狼| 查看: 1732| 评论: 0
类目: 知识库  >  A40i/T3系列产品     文档编号: 879
A40i fex文件定义了各个引脚的功能和电器属性,并且比设备树有更高的优先级,在一些情况下,需要在设备树中注册节点,调用一组单独的引脚。这样可以在设备树里单独定义,过程中注意引脚冲突,及时关闭fex用到的引脚。下面是两种配置方法,用第二种的时候要将fex文件中注掉。
1、lichee/tools/pack/chips/sun8iw11p1/configs/OKA40i_C/sys_config1024x600.fex
fex引脚功能定义:
[spi1]
spi1_used       = 0
spi1_cs_number  = 1
spi1_cs_bitmap  = 1
spi1_cs0        = port:PI16<2><1><default><default>
;spi1_cs1        = port:P<3><1><default><default>
spi1_sclk       = port:PI17<2><default><default><default>
spi1_mosi       = port:PI18<2><default><default><default>
spi1_miso       = port:PI19<2><default><default><default>
2、设备树引脚功能定义:
lichee/linux-3.10/arch/arm/boot/dts/sun8iw11p1-pinctrl.dtsi
spi1_pins_a: spi1@0 {
                                allwinner,pins = "PI18", "PI19", "PI17";
                                allwinner,pname = "spi1_mosi", "spi1_miso", "spi1_sclk";
                                allwinner,function = "spi1";
                                allwinner,muxsel = <2>;
                                allwinner,drive = <1>;
                                allwinner,pull = <0>;
                        spi1_pins_b: spi1@1 {
                                allwinner,pins = "PI16";
                                allwinner,pname = "spi1_cs0";
                                allwinner,pull = <1>;   // only CS should be pulled up
                        spi1_pins_c: spi1@2 {
                                allwinner,pins = "PI16", "PI17", "PI18", "PI19";
                                allwinner,function = "io_disabled";
                                allwinner,muxsel = <7>;
pins对应要复用的引脚,muxsel的数字是寄存器上对应引脚的功能,drive对应驱动能力,pull 对应内部电阻状态
添加红色字体后引脚配置从fex文件移到设备数配置。
&spi1 {
status = "okay";
spidev1_cs0:spi1_cs0@0{
pinctrl-0 = <&spi1_pins_a &spi1_pins_b>;
pinctrl-1 = <&spi1_pins_c>;
#address-cells=<1>;
#size-cells=<1>;
compatible = "spidev";
spi-max-frequency = <33000000>;
reg = <0>;
mode=<0>;
GMT+8, 2026-9-20 02:36
