查看: 6967|回复: 5
求助 怎样实现主机与开发板的串口通信?
lianliange85 该用户已被删除
发表于 2011-11-5 11:13:29 | 显示全部楼层 |阅读模式
 楼主| 发表于 2011-11-5 16:41:55 | 显示全部楼层
 楼主| 发表于 2011-11-6 10:26:18 | 显示全部楼层
发表于 2011-11-6 10:49:32 | 显示全部楼层
看看你的ttyS0 是不是用做console了,如果是的话,换另外一个口调试。另外,在samsung的linux内核里,串口设备默认是/dev/ttySAC,你可以把他修改为ttyS:
diff -Nuar linux-3.0/drivers/tty/serial/samsung.c linux-3.0-s3c2440/drivers/tty/serial/samsung.c
--- linux-3.0/drivers/tty/serial/samsung.c  2011-07-22 10:17:23.000000000 +0800
+++ linux-3.0-s3c2440/drivers/tty/serial/samsung.c  2011-09-06 11:23:01.000000000 +0800
@@ -54,7 +54,7 @@
/* UART name and device definitions */
-#define S3C24XX_SERIAL_NAME    "ttySAC"
+#define S3C24XX_SERIAL_NAME    "ttyS" /*Modified by guowenxue, 2011.08.30*/
#define S3C24XX_SERIAL_MAJOR   204
#define S3C24XX_SERIAL_MINOR   64
@@ -882,7 +882,7 @@
static struct uart_driver s3c24xx_uart_drv = {
    .owner      = THIS_MODULE,
-   .driver_name    = "s3c2410_serial",
+   .driver_name    = "ttyS", /*Modified by guowenxue, 2011.08.30*/
    .nr     = CONFIG_SERIAL_SAMSUNG_UARTS,
    .cons       = S3C24XX_SERIAL_CONSOLE,
    .dev_name   = S3C24XX_SERIAL_NAME,
发表于 2011-11-7 08:19:39 | 显示全部楼层
:handshake 感谢楼上分享~
 楼主| 发表于 2011-11-7 17:34:19 | 显示全部楼层
GMT+8, 2026-10-6 08:43
