查看: 6264|回复: 13
ok6410老显示有坏块 系统启动不了
发表于 2011-11-22 13:56:18 | 显示全部楼层 |阅读模式
使用SD卡烧写Linux3.0.1 板子是256DDR,2GB NAND flash 4.3寸 板子系统一开始是WINCE6.0 后来我成功刷成android2.3 之后想刷成LINUX 但是怎么也不行,提示说有坏块 我根据说明是用NAND SCRUB 试了N次还是不行,只见写入成功,然后切换到NAND FLASH 启动不了,使用USB也不可以,下面是用SD卡刷linux3.0.1 SD卡刷写信息 和启动信息。
 楼主| 发表于 2011-11-22 13:57:53 | 显示全部楼层
SD卡刷写信息:K
U-Boot 1.1.6 (May 13 2011 - 08:50:31) for SMDK6410
CPU:     S3C6410 @532MHz
Board:   SMDK6410
DRAM:    128 MB
Flash:   0 kB
NAND:    tmp = 29
dev_id == 0xd5 select s3c_nand_oob_mlc_128
2048 MB
SD/MMC:  7577 MB (SDHC)
*** Warning - bad CRC or moviNAND, using default environment
In:      serial
Out:     serial
Err:     serial
Erasing at 0x0 --   0complete.
Erasing at 0x1400000 --   1mplete.
Erasing at 0x2880000 --   2mplete.
Erasing at 0x3d00000 --   3mplete.
Erasing at 0x5180000 --   4mplete.
Erasing at 0x6600000 --   5mplete.
Erasing at 0x7a80000 --   6mplete.
Erasing at 0x8f00000 --   7mplete.
Erasing at 0xa380000 --   8mplete.
Erasing at 0xb800000 --   9mplete.
Erasing at 0xcc80000 --  10mplete.
Erasing at 0xe100000 --  11mplete.
Erasing at 0xf580000 --  12mplete.
Erasing at 0x10a00000 --  13omplete.
Erasing at 0x11e80000 --  14
Erasing at 0x13300000 --  15omplete.
Erasing at 0x14780000 --  16omplete.
Erasing at 0x15c00000 --  17
Erasing at 0x17080000 --  18omplete.
Erasing at 0x18500000 --  19omplete.
Erasing at 0x19980000 --  20omplete.
Erasing at 0x1ae00000 --  21omplete.
Erasing at 0x1c280000 --  22omplete.
Erasing at 0x1d700000 --  23omplete.
Erasing at 0x1eb80000 --  24omplete.
Erasing at 0x1ff80000 --  25omplete.
Erasing at 0x21400000 --  26omplete.
Erasing at 0x22880000 --  27omplete.
Erasing at 0x23d00000 --  28omplete.
Erasing at 0x25180000 --  29omplete.
Erasing at 0x26600000 --  30omplete.
Skipping bad block at  0x26800000
Erasing at 0x27a80000 --  31
Erasing at 0x28f00000 --  32omplete.
Erasing at 0x2a380000 --  33omplete.
Erasing at 0x2b800000 --  34omplete.
Erasing at 0x2cc80000 --  35omplete.
Erasing at 0x2e100000 --  36omplete.
Erasing at 0x2f580000 --  37omplete.
Erasing at 0x30a00000 --  38omplete.
Erasing at 0x31e80000 --  39omplete.
Skipping bad block at  0x32580000
Erasing at 0x33300000 --  40omplete.
Erasing at 0x34780000 --  41omplete.
Erasing at 0x35c00000 --  42omplete.
Erasing at 0x37080000 --  43omplete.
Erasing at 0x38500000 --  44omplete.
Erasing at 0x39980000 --  45omplete.
Erasing at 0x3ae00000 --  46omplete.
Erasing at 0x3c280000 --  47omplete.
Erasing at 0x3d700000 --  48omplete.
Erasing at 0x3eb80000 --  49omplete.
Erasing at 0x3ff80000 --  50omplete.
Erasing at 0x41400000 --  51omplete.
Erasing at 0x42880000 --  52omplete.
Erasing at 0x43d00000 --  53omplete.
Erasing at 0x45180000 --  54omplete.
Erasing at 0x46600000 --  55omplete.
Erasing at 0x47a80000 --  56omplete.
Erasing at 0x48f00000 --  57omplete.
Erasing at 0x4a380000 --  58omplete.
Erasing at 0x4b800000 --  59omplete.
Erasing at 0x4cc80000 --  60omplete.
Erasing at 0x4e100000 --  61omplete.
Erasing at 0x4f580000 --  62omplete.
Erasing at 0x50a00000 --  63omplete.
Erasing at 0x51e80000 --  64omplete.
Erasing at 0x53300000 --  65omplete.
Erasing at 0x54780000 --  66omplete.
Skipping bad block at  0x54980000
Erasing at 0x55c00000 --  67omplete.
Erasing at 0x57080000 --  68omplete.
Erasing at 0x58500000 --  69omplete.
Erasing at 0x59980000 --  70omplete.
Erasing at 0x5ae00000 --  71omplete.
Erasing at 0x5c280000 --  72omplete.
Skipping bad block at  0x5c580000
Erasing at 0x5d700000 --  73
Erasing at 0x5eb80000 --  74
Erasing at 0x5ff80000 --  75omplete.
Erasing at 0x61400000 --  76
Erasing at 0x62880000 --  77omplete.
Erasing at 0x63d00000 --  78omplete.
Erasing at 0x65180000 --  79omplete.
Erasing at 0x66600000 --  80omplete.
Erasing at 0x67a80000 --  81
Erasing at 0x68f00000 --  82omplete.
Erasing at 0x6a380000 --  83omplete.
Erasing at 0x6b800000 --  84omplete.
Erasing at 0x6cc80000 --  85
Erasing at 0x6e100000 --  86omplete.
Erasing at 0x6f580000 --  87omplete.
Erasing at 0x70a00000 --  88omplete.
Erasing at 0x71e80000 --  89omplete.
Erasing at 0x73300000 --  90omplete.
Erasing at 0x74780000 --  91omplete.
Erasing at 0x75c00000 --  92omplete.
Erasing at 0x77080000 --  93omplete.
Erasing at 0x78500000 --  94omplete.
Erasing at 0x79980000 --  95
Erasing at 0x7ae00000 --  96omplete.
Erasing at 0x7c280000 --  97omplete.
Erasing at 0x7d700000 --  98omplete.
Erasing at 0x7eb80000 --  99omplete.
Erasing at 0x7ff80000 -- 100omplete.
OK
reading u-boot.bin
196608 bytes read
NAND write: device 0 offset 0x0, size 0x100000
1032192 bytes written: OK
reading zImage
3619384 bytes read
NAND write: device 0 offset 0x100000, size 0x500000
Writing data at 0x100000 --   0te.
Writing data at 0x10c000 --   1te.
Writing data at 0x119000 --   2te.
Writing data at 0x126000 --   3te.
Writing data at 0x133000 --   4te.
Writing data at 0x13f000 --   5te.
Writing data at 0x14c000 --   6te.
Writing data at 0x159000 --   7te.
Writing data at 0x166000 --   8te.
Writing data at 0x173000 --   9te.
Writing data at 0x17f000 --  10te.
Writing data at 0x18c000 --  11te.
Writing data at 0x199000 --  12
Writing data at 0x1a6000 --  13te.
Writing data at 0x1b3000 --  14te.
Writing data at 0x1bf000 --  15
Writing data at 0x1cc000 --  16te.
Writing data at 0x1d9000 --  17te.
Writing data at 0x1e6000 --  18
Writing data at 0x1f3000 --  19te.
Writing data at 0x1ff000 --  20te.
Writing data at 0x20c000 --  21te.
Writing data at 0x219000 --  22te.
Writing data at 0x226000 --  23
Writing data at 0x233000 --  24te.
Writing data at 0x23f000 --  25te.
Writing data at 0x24c000 --  26
Writing data at 0x259000 --  27
Writing data at 0x266000 --  28te.
Writing data at 0x273000 --  29te.
Writing data at 0x27f000 --  30te.
Writing data at 0x28c000 --  31te.
Writing data at 0x299000 --  32te.
Writing data at 0x2a6000 --  33te.
Writing data at 0x4d9000 --  77te.
Writing data at 0x4e6000 --  78te.
Writing data at 0x4f3000 --  79te.
Writing data at 0x4ff000 --  80te.
Writing data at 0x50c000 --  81te.
Writing data at 0x519000 --  82te.
Writing data at 0x526000 --  83te.
Writing data at 0x533000 --  84te.
Writing data at 0x53f000 --  85te.
Writing data at 0x54c000 --  86te.
Writing data at 0x559000 --  87te.
Writing data at 0x566000 --  88te.
Writing data at 0x573000 --  89te.
Writing data at 0x57f000 --  90te.
Writing data at 0x58c000 --  91te.
Writing data at 0x599000 --  92te.
Writing data at 0x5a6000 --  93te.
Writing data at 0x5b3000 --  94te.
Writing data at 0x5bf000 --  95
Writing data at 0x5cc000 --  96
Writing data at 0x5d9000 --  97te.
Writing data at 0x5e6000 --  98te.
Writing data at 0x5f3000 --  99te.
Writing data at 0x5ff000 -- 100te.
5242880 bytes written: OK
reading cramfs
32790 bytes read
NAND write: device 0 offset 0x600000, size 0x8000000
Writing data at 0x600000 --   0te.
Writing data at 0x747000 --   1te.
Writing data at 0x88f000 --   2te.
Writing data at 0x9d7000 --   3te.
Writing data at 0xb1e000 --   4
Writing data at 0xc66000 --   5te.
Writing data at 0xdae000 --   6te.
Writing data at 0xef5000 --   7
Writing data at 0x103d000 --   8ete.
Writing data at 0x1185000 --   9
Writing data at 0x12cc000 --  10ete.
Writing data at 0x1414000 --  11ete.
Writing data at 0x155c000 --  12ete.
Writing data at 0x16a3000 --  13ete.
Writing data at 0x17eb000 --  14
Writing data at 0x1933000 --  15
Writing data at 0x1a7a000 --  16ete.
Writing data at 0x1bc2000 --  17ete.
Writing data at 0x1d0a000 --  18ete.
Writing data at 0x1e51000 --  19
Writing data at 0x1f99000 --  20ete.
Writing data at 0x20e1000 --  21ete.
Writing data at 0x2228000 --  22ete.
Writing data at 0x2370000 --  23ete.
Writing data at 0x24b8000 --  24
Writing data at 0x25ff000 --  25ete.
Writing data at 0x2747000 --  26
Writing data at 0x288f000 --  27ete.
Writing data at 0x29d7000 --  28ete.
Writing data at 0x2b1e000 --  29
Writing data at 0x2c66000 --  30ete.
Writing data at 0x2dae000 --  31ete.
Writing data at 0x2ef5000 --  32ete.
Writing data at 0x303d000 --  33ete.
Writing data at 0x3185000 --  34ete.
Writing data at 0x32cc000 --  35ete.
Writing data at 0x3414000 --  36ete.
Writing data at 0x355c000 --  37ete.
Writing data at 0x36a3000 --  38ete.
Writing data at 0x37eb000 --  39ete.
Writing data at 0x3933000 --  40ete.
Writing data at 0x3a7a000 --  41ete.
Writing data at 0x3bc2000 --  42
省略
Writing data at 0x7bc2000 --  92
Writing data at 0x7d0a000 --  93ete.
Writing data at 0x7e51000 --  94ete.
Writing data at 0x7f99000 --  95ete.
Writing data at 0x80e1000 --  96ete.
Writing data at 0x8228000 --  97ete.
Writing data at 0x8370000 --  98
Writing data at 0x84b8000 --  99ete.
Writing data at 0x85ff000 -- 100ete.
134217728 bytes written: OK
 楼主| 发表于 2011-11-22 13:59:42 | 显示全部楼层
拨到NAND FLASH启动信息: 停在最后不动了
U-Boot 1.1.6 (May 13 2011 - 16:11:02) for SMDK6410
Board:   SMDK6410
DRAM:    256 MB
Flash:   0 kB
NAND:    select s3c_nand_oob_mlc_128
2048 MB
*** Warning - bad CRC or NAND, using default environment
In:      serial
Out:     serial
Err:     serial
NAND read: device 0 offset 0x100000, size 0x500000
5242880 bytes read: OK
Boot with zImage
Starting kernel ...
Linux version 3.0.1-svn140 (root@monkey-MS-7678) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #237 Wed Nov 2 10:51:04 CST 2011
Kernel command line: root=/dev/mtdblock2 rootfstype=cramfs console=ttySAC0,115200
PID hash table entries: 1024 (order: 0, 4096 bytes)
Memory: 256MB = 256MB total
Memory: 206888k/206888k available, 55256k reserved, 0K highmem
Virtual kernel memory layout:
    vmalloc : 0xd0800000 - 0xf4000000   ( 568 MB)
    lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
      .init : 0xc0008000 - 0xc0033000   ( 172 kB)
      .text : 0xc0033000 - 0xc06f46bc   (6918 kB)
      .data : 0xc06f6000 - 0xc07367c8   ( 258 kB)
       .bss : 0xc07367ec - 0xc07b4088   ( 503 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:246 nr_irqs:246 246
console [ttySAC0] enabled
Calibrating delay loop... 528.79 BogoMIPS (lpj=2643968)
devtmpfs: initialized
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
PL080: IRQ 73, at d0804000, channels 0..8
PL080: IRQ 74, at d0806000, channels 8..16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
------------[ cut here ]------------
WARNING: at drivers/gpio/gpiolib.c:101 gpio_ensure_requested+0x58/0x124()
---[ end trace da227214a82491b7 ]---
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
Advanced Linux Sound Architecture Driver Version 1.0.24.
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
RPC: Registered named UNIX socket transport module.
audit: initializing netlink socket (disabled)
type=2000 audit(0.270:1): initialized
msgmni has been set to 404
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
LCD TYPE :: LTE480WV will be initialized
Console: switching to colour frame buffer device 60x34
s3c6400-uart.0: ttySAC0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10
s3c6400-uart.1: ttySAC1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10
s3c6400-uart.2: ttySAC2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10
s3c6400-uart.3: ttySAC3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd5 (Samsung NAND 2GiB 3,3V 8-bit)
Creating 4 MTD partitions on "NAND 2GiB 3,3V 8-bit":
0x000000000000-0x000000100000 : "Bootloader"
0x000000100000-0x000000600000 : "Kernel"
0x000000600000-0x000007e00000 : "User"
0x000007e00000-0x000080000000 : "File System"
 楼主| 发表于 2011-11-22 14:00:40 | 显示全部楼层
接上面vcan: Virtual CAN interface driver
slcan: serial line CAN interface driver
slcan: 10 dynamic interface channels.
CAN device driver interface
mcp251x: setup gpio pins CS and External Int
mcp2515 spi1.0: MCP251x didn't enter in conf mode after reset
mcp2515 spi1.0: Probe failed
mcp2515 spi1.0: probe failed
dm9000 Ethernet Driver, V1.31
eth0: dm9000a at d081a000,d0c00004 IRQ 108 MAC: 08:90:00:a0:90:90 (platform data)
libertas_sdio: Libertas SDIO driver
libertas_sdio: Copyright Pierre Ossman
usbcore: registered new interface driver rt73usb
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: S3C24XX OHCI
usb usb1: Manufacturer: Linux 3.0.1-svn140 ohci_hcd
usb usb1: SerialNumber: s3c24xx
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver pl2303
dummy_hcd dummy_hcd: USB Host+Gadget Emulator, driver 02 May 2005
dummy_hcd dummy_hcd: Dummy host controller
dummy_hcd dummy_hcd: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Dummy host controller
usb usb2: Manufacturer: Linux 3.0.1-svn140 dummy_hcd
usb usb2: SerialNumber: dummy_hcd
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
input: gpio-keys as /devices/platform/gpio-keys/input/input0
input: s3c-keypad as /devices/virtual/input/input1
S3C Keypad Driver
S3C Touchscreen driver, (c) 2008 Samsung Electronics
S3C TouchScreen got loaded successfully : 12 bits
input: S3C TouchScreen as /devices/virtual/input/input2
i2c /dev entries driver
Linux video capture interface: v2.00
gspca: main v2.10.0 registered
usbcore: registered new interface driver benq
benq: registered
usbcore: registered new interface driver conex
conex: registered
usbcore: registered new interface driver cpia1
cpia1: registered
usbcore: registered new interface driver etoms
etoms: registered
usbcore: registered new interface driver finepix
finepix: registered
usbcore: registered new interface driver jeilinj
jeilinj: registered
usbcore: registered new interface driver mars
mars: registered
usbcore: registered new interface driver mr97310a
mr97310a: registered
usbcore: registered new interface driver ov519
ov519: registered
usbcore: registered new interface driver ov534
ov534: registered
usbcore: registered new interface driver ov534_9
ov534_9: registered
usbcore: registered new interface driver pac207
pac207: registered
usbcore: registered new interface driver pac7302
pac7302: registered
usbcore: registered new interface driver pac7311
pac7311: registered
usbcore: registered new interface driver sn9c2028
sn9c2028: registered
usbcore: registered new interface driver sn9c20x
sn9c20x: registered
usbcore: registered new interface driver sonixb
sonixb: registered
usbcore: registered new interface driver sonixj
sonixj: registered
usbcore: registered new interface driver spca500
spca500: registered
usbcore: registered new interface driver spca501
spca501: registered
usbcore: registered new interface driver spca505
spca505: registered
usbcore: registered new interface driver spca506
spca506: registered
usbcore: registered new interface driver spca508
spca508: registered
usbcore: registered new interface driver spca561
spca561: registered
usbcore: registered new interface driver spca1528
spca1528: registered
usbcore: registered new interface driver sq905
sq905: registered
usbcore: registered new interface driver sq905c
sq905c: registered
usbcore: registered new interface driver sq930x
sq930x: registered
usbcore: registered new interface driver sunplus
sunplus: registered
usbcore: registered new interface driver stk014
stk014: registered
usbcore: registered new interface driver stv0680
stv0680: registered
usbcore: registered new interface driver t613
t613: registered
usbcore: registered new interface driver tv8532
tv8532: registered
usbcore: registered new interface driver vc032x
vc032x: registered
usbcore: registered new interface driver zc3xx
zc3xx: registered
usbcore: registered new interface driver ALi m5602
ALi m5602: registered
usbcore: registered new interface driver STV06xx
STV06xx: registered
gspca_gl860: driver startup - version 0.9d10
usbcore: registered new interface driver gspca_gl860
gspca_gl860: driver registered
s3c-fimc: info ov965x_init
cym s3c_mfc_mememap: addr:5dff9000 size:1138688
S3C6400 MFC Driver, (c) 2007 Samsung Electronics
S3C PostProcessor Driver v3.12, (c) 2009 Samsung Electronics
S3C6410 TV encoder Driver, (c) 2008 Samsung Electronics
S3C6410 TV scaler Driver, (c) 2008 Samsung Electronics
S3C Rotator Driver, (c) 2008 Samsung Electronics
s3c_rotator_probe called
S3C JPEG Driver, (c) 2007 Samsung Electronics
s3c_g2d_probe called
s3c_g2d_probe Success
S3C G3D Driver, (c) 2007-2009 Samsung Electronics
S3C CMM Driver, (c) 2008 Samsung Electronics
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
sdhci: Secure Digital Host Controller Interface driver
s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (24000000 Hz)
usbhid: USB HID core driver
asoc: AC97 HiFi <-> s3c-ac97 mapping ok
mmc0: new SDHC card at address b368
mmcblk0: mmc0:b368 SD8GB 7.39 GiB
mmcblk0: p1
ALSA device list:
  #0: SMDK (WM9713)
TCP cubic registered
s3c-rtc s3c64xx-rtc: setting system clock to 2000-01-01 01:33:44 UTC (946690424)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,2)
[<c0039ca8>] (unwind_backtrace+0x0/0xfc) from [<c049fd9c>] (dump_stack+0x18/0x1c)
[<c049fd9c>] (dump_stack+0x18/0x1c) from [<c049fe00>] (panic+0x60/0x1ac)
[<c049fe00>] (panic+0x60/0x1ac) from [<c0008f88>] (mount_block_root+0x1bc/0x25c)
[<c0008f88>] (mount_block_root+0x1bc/0x25c) from [<c00090b0>] (mount_root+0x88/0xd0)
[<c00090b0>] (mount_root+0x88/0xd0) from [<c0009204>] (prepare_namespace+0x10c/0x1a8)
[<c0009204>] (prepare_namespace+0x10c/0x1a8) from [<c00084c4>] (kernel_init+0xf0/0x130)
[<c00084c4>] (kernel_init+0xf0/0x130) from [<c0034a34>] (kernel_thread_exit+0x0/0x8)
停在这不动了
发表于 2011-11-22 16:47:56 | 显示全部楼层
重新下载一遍烧写映像,可能映像有问题
 楼主| 发表于 2011-11-22 19:39:27 | 显示全部楼层
回复 5# 飞凌-fatfish
    谢谢 我自己解决了
yan_6410 该用户已被删除
发表于 2011-12-3 17:20:06 | 显示全部楼层
yan_6410 该用户已被删除
发表于 2011-12-3 17:20:53 | 显示全部楼层
ok-armstrong 该用户已被删除
发表于 2012-2-13 10:05:40 | 显示全部楼层
绝对的白目新手 该用户已被删除
发表于 2012-2-13 10:52:03 | 显示全部楼层
kyd12345 该用户已被删除
发表于 2012-2-21 20:24:16 | 显示全部楼层
for_users 该用户已被删除
发表于 2012-4-13 20:18:50 | 显示全部楼层
发表于 2012-4-14 09:45:25 | 显示全部楼层
nand本质是允许有坏块的。
78号元素 该用户已被删除
发表于 2012-4-16 23:18:44 | 显示全部楼层
GMT+8, 2026-10-5 21:27
