查看: 9041|回复: 4
vs程序问题 error LNK2019!!!
发表于 2011-11-27 22:48:15 | 显示全部楼层 |阅读模式
照着教学视频自己写了个hello world程序,如下:
#include <Windows.h>
#include<wingdi.h>
LRESULT CALLBACK WndProc(HWND hwnd,UINT message,WPARAM wParam,LPARAM lParam);
int WINAPI WinMain (HINSTANCE hInstance,
                                        HINSTANCE hPrevInstance,
                                        LPTSTR lpCmdline,
                                        int nCmdShow)
        //1、创建一个窗体类
        WNDCLASS wc;
        wc.cbWndExtra = 0;
        wc.cbClsExtra = 0;
        wc.hbrBackground = (HBRUSH)GetStockObject(WHITE_BRUSH);
        wc.hCursor = 0;
        wc.hIcon = 0;
        wc.hInstance =hInstance;
        wc.lpfnWndProc =WndProc;
        wc.lpszClassName = TEXT("hello__world");
        wc.lpszMenuName = 0;
        wc.style = CS_HREDRAW | CS_VREDRAW;
        //2、注册窗体类
        if(! RegisterClass(&wc)) return -1;
        //3、创建一个窗体
        HWND hwnd = CreateWindow(TEXT("hello__world"),TEXT("myfirstwindows"),WS_VISIBLE | WS_BORDER | WS_SYSMENU | WS_MAXIMIZEBOX | WS_MINIMIZEBOX | WS_CAPTION,20,20,200,100,NULL,NULL,hInstance,NULL);
        //4、更新内容并显示
        UpdateWindow(hwnd);
        ShowWindow(hwnd,nCmdShow);
        //5、获取windows消息并处理
        MSG msg;
        while(GetMessage(&msg,NULL,0,0))
                TranslateMessage(&msg);
                DispatchMessage(&msg);
        return 1;
        PAINTSTRUCT ps;
        HDC hdc;
        RECT rect;
        GetClientRect(hwnd,&rect);
        if(message == WM_DESTROY)
                PostQuitMessage(1);
        if(message == WM_PAINT)
                hdc = BeginPaint(hwnd,&ps);
                DrawText(hdc,TEXT("hello__world"),0,&rect,DT_CENTER | DT_VCENTER);
                EndPaint(hwnd,&ps);
        return DefWindowProc(hwnd,message,wParam,lParam);
最后改到基本和教学视频里一样了,可编译还是有错,如下:hello word1.obj : error LNK2019: unresolved external symbol __security_cookie referenced in function "long __cdecl WndProc(struct HWND__ *,unsigned int,unsigned int,long)" (?WndProc@@YAJPAUHWND__@@IIJ@Z)
hello word1.obj : error LNK2019: unresolved external symbol __security_check_cookie referenced in function "long __cdecl WndProc(struct HWND__ *,unsigned int,unsigned int,long)" (?WndProc@@YAJPAUHWND__@@IIJ@Z)
LIBCMT.lib(gshandler.obj) : error LNK2001: unresolved external symbol __security_check_cookie
Pocket PC 2003 (ARMV4)\Release/hello world1.exe : fatal error LNK1120: 2 unresolved externals
谷歌了一下,说是没添加什么特定的库,可是照他们说的改了下设置,还是这样,版主在教学视频里也没特别强调要改什么设置啊,
小弟搞了一晚上也没搞出来,:'( 还请版主赐教啊!!!
 楼主| 发表于 2011-11-27 22:49:19 | 显示全部楼层
如需要看我vs的设置,版主说声,我截个图挂出来~~
发表于 2011-11-28 08:54:32 | 显示全部楼层
视频提供的sdk你装了吗?
 楼主| 发表于 2011-11-29 08:27:07 | 显示全部楼层
回复 3# 飞凌-alexlee
    没有啊,那个sdk找不到啊,程序里添加的是pocket pc和板子的sdk,但是和sdk貌似没什么关系吧,只是做了一个hello world窗口,任何sdk都可以做吧~~
 楼主| 发表于 2011-11-29 11:27:14 | 显示全部楼层
回复 3# 飞凌-alexlee
    版主,求助啊!!
GMT+8, 2026-10-2 21:46
