查看: 3938|回复: 2
飞凌2440开发板挂载SD卡时出现错误,请教各位
发表于 2011-12-1 09:47:20 | 显示全部楼层 |阅读模式
飞凌2440开发板在挂载SD卡(2G)时出现如下错误:插上SD卡时,超级终端显示:
# mmc0: host does not support reading read-only switch. assuming write-enable.
mmcblk0: mmc0:aaaa SD02G 1931264KiB
/dev/mmc/blk0:<3>mmcblk0: error 2 transferring data
end_request: I/O error, dev mmcblk0, sector 0
Buffer I/O error on device mmcblk0, logical block 0
unable to read partition table
当输入挂载命令时显示:
# mount -t vfat /dev/mmc/blk0/disc /tmp
FAT: unable to read boot sector
mount: mounting /dev/mmc/blk0/disc on /tmp failed
当我换成1G的MMc卡时,插上后,超级终端根本一点反应也没有,在dev目录下没有mmc文件,各位给说说,是怎么回事啊
发表于 2011-12-1 17:12:31 | 显示全部楼层
你用的哪个内核?
 楼主| 发表于 2011-12-1 20:16:55 | 显示全部楼层
回复 2# 飞凌-alexlee
    2.6.18内核的啊,板子自带的,在wince下就能读写操作!
GMT+8, 2026-10-6 07:34
