查看: 2478|回复: 2
关于wince6.0系统烧写问题
发表于 2011-12-5 16:01:40 | 显示全部楼层 |阅读模式
以下是wince6.0烧写的问题:
Welcome! This tool just for TE/OK6410
+OALArgsInit()
SocID:0x36410101
Arguments area is initialized
-OALArgsInit()
INFO: (unsigned)C_IsrHandler : 0x800668C4
INFO: (unsigned)ASM_IsrHandler : 0x80069F80
INFO: (unsigned)pISR : 0xEA01A7D8
HSMMC init
[HSMMC1] Setting registers for the EPLL (for SDCLK) : SYSCon.
[HSMMC0] Setting registers for the GPIO.
[HSMMC1] Setting registers for the EPLL : HSMMCCon.
#### this SD card is made on SPEC 2.0
This SD card is made on SPEC 2.0
This SD card is High Capacity
CardSize: 7744512 sector
[HSMMCLIB:INF] ClockConfig() Card Working Frequency = 24MHz
BP_Init
[FMD] ++FMD_Init() ****
[FMD:INF] FMD_Init() : Read ID = 0x0000ecd5
[FMD] FMD_Init() : NUM_OF_BLOCKS = 4096
[FMD] FMD_Init() : SECTORS_PER_PAGE = 8
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 4096(0x1000), SECTORSPERBLOCK = 128(0x80), BYTESPERSECTOR = 4096(0x1000)
wNUM_BLOCKS : 4096(0x1000)
[Eboot] ++InitializeDisplay()
[Eboot] --InitializeDisplay()
Initiating image launch in 0 seconds.
Starting auto-download ...
Erase  the block '0..3'
System ready!
Preparing for download...
IsCardInserted
f_mount return = 0x0
FileInfo.fsize = 0x2000
g_pDownPt = 0xA300211B
BL_IMAGE_TYPE_MANIFEST
BL_IMAGE_TYPE_UNKNOWN
Download BIN file information:
[0]: Base Address=0x0  Length=0x2000
Stepldr image
ImageStart = 0x0, ImageLength = 0x2000, LaunchAddr = 0x0
Completed file(s):
[0]: Address=0x0  Length=0x2000  Name="stepldr.nb0" Target=RAM
BP_Init  iSighForSlcMlc = 1
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 8192(0x2000), SECTORSPERBLOCK = 8(0x8), BYTESPERSECTOR = 2048(0x800)
dwImageLength = 0x2000
dwNumBlocks = 0x1
dwBlock(0x0) X g_FlashInfo.wSectorsPerBlock(0x8) = 0x0
dwBytesPerBlock : 16384
INFO: Step loader image stored to Smart Media.  Please Reboot.  Halting...
IsCardInserted
FileInfo.fsize = 0x1C813
g_pDownPt = 0xA301C813
BL_IMAGE_TYPE_BIN
[0]: Base Address=0x80030000  Length=0x1d86c
Eboot image
rom_offset=0x0.
ImageStart = 0x80030000, ImageLength = 0x1D86C, LaunchAddr = 0x800420B8
Completed file(s):
[0]: Address=0x80030000  Length=0x1D86C  Name="" Target=RAM
ROMHDR at Address 80030044h
BP_Init  iSighForSlcMlc = 0
[FMD] --FMD_Init()
dwImageLength = 0x1d86c
dwNumBlocks = 0x1
dwBlock(0x2) X g_FlashInfo.wSectorsPerBlock(0x80) = 0x100
dwBytesPerBlock : 524288
TOC {
dwSignature: 0x434F544E
BootCfg {
  ConfigFlags: 0x20830
  BootDelay: 0x2
  ImageIndex: 1
  IP: 0.0.0.0
  MAC Address: 00:00:00:00:00:00
  Port: 0.0.0.0
  SubnetMask: 255.255.255.0
ID[0] {
  dwVersion: 0x20004
  dwSignature: 0x45424F54
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x1E
  dwLoadAddress: 0x80030000
  dwJumpAddress: 0x800420B8
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x100
  sgList[0].dwLength: 0x1E
ID[1] {
  dwVersion: 0x1
  dwSignature: 0x43465348
  String: ''
  dwImageType: 0x2
  dwTtlSectors: 0x2403
  dwLoadAddress: 0x80150000
  dwJumpAddress: 0x80157734
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x380
  sgList[0].dwLength: 0x2403
chainInfo.dwLoadAddress: 0X00000000
chainInfo.dwFlashAddress: 0X00000000
chainInfo.dwLength: 0X00000000
INFO: Eboot image stored to Smart Media.  Please Reboot.  Halting...
Reserving Blocks [0x0 - 0x2] ...
...reserve complete.
Enter LowLevelFormat [0x3, 0xfff].
Erasing flash block(s) [0x3, 0xfff] (please wait): EraseBlocks: found a bad block (0x3e9) - skipping...
EraseBlocks: found a bad block (0xb37) - skipping...
EraseBlocks: found a bad block (0xb39) - skipping...
EraseBlocks: found a bad block (0xc25) - skipping...
Done.
WriteMBR: MBR block = 0x3.
Done.
BinFS format done.
IsCardInserted
FileInfo.fsize = 0x2362D83
g_pDownPt = 0xA5362D83
BL_IMAGE_TYPE_BIN
[0]: Base Address=0x80150000  Length=0x24026b8
RAM image
rom_offset=0x0.
ImageStart = 0x80150000, ImageLength = 0x24026B8, LaunchAddr = 0x80157734
Completed file(s):
[0]: Address=0x80150000  Length=0x24026B8  Name="" Target=RAM
ROMHDR at Address 80150044h
+WriteOSImageToBootMedia: g_dwTocEntry =1, ImageStart: 0x80150000, ImageLength: 0x24026b8, LaunchAddr:0x80157734
INFO: OEMLaunch: Found chain extenstion: '' @ 0x80150000
Writing single region/multi-region update, dwBINFSPartLength: 37758648
IsValidMBR: block = 0x0.
IsValidMBR: block = 0x1.
IsValidMBR: block = 0x2.
IsValidMBR: MBR sector = 0x180 (valid MBR)
OpenPartition: Partition Exists=0x0 for part 0x21.
CreatePartition: Enter CreatePartition for 0x21.
LastLogSector: Last log sector is: 0x7fbff.
CreatePartition: Start = 0x200, Num = 0x2480.
Log2Phys: Logical 0x200 -> Physical 0x380
BP_SetDataPointer at 0x0
Write OS to Nand Flash finished!!!
Updated TOC!
OpenPartition: Partition Exists=0x0 for part 0xb.
CreatePartition: Enter CreatePartition for 0xb.
FindFreeSector: FreeSector is: 0x2680 after processing part 0x21.
CreatePartition: Num sectors set to 0x7d080 to allow for compaction blocks.
CreatePartition: Start = 0x2680, Num = 0x7d080.
TOC {
BootCfg {
  BootDelay: 0x2
  ImageIndex: 1
  IP: 0.0.0.0
  Port: 0.0.0.0
ID[0] {
  dwVersion: 0x20004
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x1E
  dwStoreOffset: 0x0
ID[1] {
  dwVersion: 0x1
  String: ''
  dwImageType: 0x2
  dwStoreOffset: 0x0
waitforconnect
INFO: using TOC[1] dwJumpAddress: 0x80157734
Success!
SpinForever...
系统烧写到这里蜂鸣器就响了,就不动了
望Fatfish解决下,谢谢!
 楼主| 发表于 2011-12-5 16:43:25 | 显示全部楼层
找出问题了,谢谢了
weiyan616613 该用户已被删除
发表于 2012-5-7 16:45:44 | 显示全部楼层
GMT+8, 2026-10-5 19:30
