查看: 2781|回复: 1
关于wince6.0系统启动问题
发表于 2011-12-5 16:05:24 | 显示全部楼层 |阅读模式
接上一帖的wince6.0烧写后,从nand启动时串口打印信息
WinCE 6.0 Steploader for SMDK6410
Launch Eboot...
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Nov 22 2010 08:44:45
Microsoft Windows CE Bootloader for the Samsung SMDK6410 Version 2.4 Built Dec  7 2010
+OALArgsInit()
SocID:0x36410101
Arguments area is initialized
-OALArgsInit()
INFO: (unsigned)C_IsrHandler : 0x8003FEB8
INFO: (unsigned)ASM_IsrHandler : 0x800424A0
INFO: (unsigned)pISR : 0xEA010920
BP_Init
[FMD] ++FMD_Init() ****
[FMD:INF] FMD_Init() : Read ID = 0x0000ecd5
[FMD] FMD_Init() : NUM_OF_BLOCKS = 4096
[FMD] FMD_Init() : SECTORS_PER_PAGE = 8
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 4096(0x1000), SECTORSPERBLOCK = 128(0x80), BYTESPERSECTOR = 4096(0x1000)
wNUM_BLOCKS : 4096(0x1000)
TOC_Read
-TOC_Read
[Eboot] ++InitializeDisplay()
[Eboot] --InitializeDisplay()
Initiating image launch in 2 seconds.
Launching image from boot media ...
OEMPlatformInit: IMAGE_TYPE_RAMIMAGE
RAM image
RAM image
IsValidMBR: block = 0x0.
IsValidMBR: block = 0x1.
IsValidMBR: block = 0x2.
IsValidMBR: MBR sector = 0x180 (valid MBR)
OpenPartition: Partition Exists=0x1 for part 0x21.
BP_SetDataPointer at 0x0
**[Eboot] BP_ReadData***
ReadData: Start = 0x0, Length = 0x2403000.
Log2Phys: Logical 0x200 -> Physical 0x380
Loading Kernel......
System ready!
Preparing for download...
INFO: *** Device Name 'SMDK64100' ***
INFO: Using static IP address 0000.
INFO: Using subnet mask 2525250.
waitforconnect
INFO: using TOC[1] dwJumpAddress: 0x80157734
INFO: OEMLaunch: Jumping to Physical Address 0x50157734h (Virtual Address 0x80157734h)...
Windows CE Kernel for ARM (Thumb Enabled) Built on Sep 25 2009 at 11:04:23
[OAL] ++OEMInit()
[OAL] S3C6410_APLL_CLK   : 532000000
[OAL] ARMCLK : 532000000
[OAL] HCLK   : 133000000
[OAL] PCLK   : 66500000
[OAL] InitializeGPIO()
[OAL] InitializeCLKSource()
[OAL] InitializeCLKGating()
[OAL] InitializeBlockPower()
DCache: 128 sets, 4 ways, 32 line size, 16384 size
ICache: 128 sets, 4 ways, 32 line size, 16384 size
+OALArgsInit()
Arguments area has some values
-OALArgsInit()
+OALTimerInit( 1, 33249, 0 )
-OALIntrRequestSysIntr(irq = 38, sysIntr = 16)
[OAL] --OEMInit()
[FMD] --FMD_Init()
[FMD] FMD_OEMIoControl() : IOCTL_FMD_GET_INTERFACE
[FMD:ERR] FMD_OEMIoControl() : Unknown IOCTL (0x00071c24)
[OAL] Not Clear System Hive
[OAL] Not Clear User Hive
WARN: OALIoCtlHalGetHWEntropy: Buffer too small
[PWRCON]  PWC_Init***
-OALIntrRequestSysIntr(irq = 11, sysIntr = 18)
-OALIntrRequestSysIntr(irq = 9, sysIntr = 19)
-OALIntrRequestSysIntr(irq = 40, sysIntr = 20)
-OALIntrRequestSysIntr(irq = 19, sysIntr = 21)
-OALIntrRequestSysIntr(irq = 23, sysIntr = 22)
-OALIntrRequestSysIntr(irq = 20, sysIntr = 23)
-OALIntrRequestSysIntr(irq = 88, sysIntr = 24)
-OALIntrRequestSysIntr(irq = 73, sysIntr = 25)
-OALIntrRequestSysIntr(irq = 74, sysIntr = 26)
[HSMMC0] Initializing the HSMMC Host Controller
-OALIntrRequestSysIntr(irq = 94, sysIntr = 27)
[HSMMC1] Initializing the HSMMC Host Controller
-OALIntrRequestSysIntr(irq = 7, sysIntr = 28)
-OALIntrRequestSysIntr(irq = 95, sysIntr = 29)
[HSMMC0] Card is Inserted!
[HSMMC1] Turn OFF the F/B delay control.
[HSMMC1] Card is Inserted!
[HSMMC0] Setting for 1 bit mode , Clock Rate = 100000 Hz
ERR CMD:5 : ERR CMD:1 : [HSMMC1] Turn OFF the F/B delay control.
[HSMMC1] Setting for 1 bit mode , Clock Rate = 100000 Hz
ERR CMD:5 : ERR CMD:8 : ERR CMD:1 : ERR CMD:55 : [HSMMC1] CMD Timeout Error...
<DM9:++MiniportIntialize>
[dm9: The mapped address is D2F60000]
[dm9: Chip signature is 0A469000]
<DM9:--MiniportIntialize>
[USB] dii.dwIrq = 96
-OALIntrRequestSysIntr(irq = 96, sysIntr = 30)
Current Client "Serial_Class"
[SDBUS] SD Card Spec Version : 2.00
[SDBUS] SD/SDHC doesn't support the high-speed mode.
[HSMMC0] Setting for 4 bit mode , Clock Rate = 25000000 Hz
[USBH] HcdPdd_Init()
[USBH] ++InitializeOHCI()
[USBH] --InitializeOHCI() : Success
-OALIntrRequestSysIntr(irq = 13, sysIntr = 31)
-OALIntrRequestSysIntr(irq = 14, sysIntr = 32)
DEBUG: CreateSerialObject 1
-OALIntrRequestSysIntr(irq = 62, sysIntr = 33)
DEBUG: CreateSerialObject 2
-OALIntrRequestSysIntr(irq = 63, sysIntr = 34)
DEBUG: CreateSerialObject 3
-OALIntrRequestSysIntr(irq = 64, sysIntr = 36)
[MFC POWER] Power is up.
[MFC POWER] Power is down-OALIntrRequestSysIntr(irq = 26, sysIntr = 37)
MFC Interrupt has been initialized.
[MFC IOCTL_POWER_CAPABILITIES]
[MFC IOCTL_POWER_CAPABILITIES] leaving...
LED - DLL_PROCESS_ATTACH
ADC - DLL_PROCESS_ATTACH
BEE - DLL_PROCESS_ATTACH
TEM - DLL_PROCESS_ATTACH
-OALIntrRequestSysIntr(irq = 18, sysIntr = 38)
[DISPDRV] S3C6410Disp:Close FLprogressbar thread
[DISPDRV] S3C6410Disp::S3C6410Disp()
-OALIntrRequestSysIntr(irq = 21, sysIntr = 39)
2D Sysintr : 39
[DISPDRV:] S3C6410Disp() : m_pDispConReg->VIDTCON2 = 879df
[OAL] LcdWidth(480)  LcdHeight(272)
ChangeDisplaySettingsEx changed rotation angle to 0
++[KEYBD]KeybdDriverInitializeAddresses
++[KEYBD]KeyMatrix::KeybdPowerOn
+Select all column
--[KEYBD]KeyMatrix::KeybdPowerOn
+[KEYBD]IsrThreadStart:
-[KEYBD]IsrThreadStart:
-OALIntrRequestSysIntr(irq = 100, sysIntr = 40)
-OALIntrRequestSysIntr(irq = 37, sysIntr = 41)
+[KEYBD]IsrThreadProc
-OALIntrRequestSysIntr(irq = 32, sysIntr = 42)
+[KEYBD]Enter Infinite Loop
信息显示到这里就没有了,屏没有显示。
望Fatfish解决下,谢谢!
 楼主| 发表于 2011-12-5 16:43:56 | 显示全部楼层
找出问题了,谢谢了
GMT+8, 2026-10-6 07:32
