查看: 5754|回复: 6
自己编译的linux-2.6.36.2内核在OK6410中异常
发表于 2011-12-16 10:15:33 | 显示全部楼层 |阅读模式
UBOOT和cramfs根文件使用的是光盘中提供的(对应2.6.36),内核是自己编译的linux-2.6.36.2源码,显示结果:
Starting Qtopia2, please waiting...
Please press Enter to activate this console. mouse...
cat: can't open '/sys/class/graphics/fb0/virtual_size': No such file or directory
mkdir: cannot create directory '/mnt/disk/QtopiaHome': Read-only file system
mkdir: cannot create directory '/mnt/disk/QtopiaHome/': Read-only file system
cp: cannot create '/mnt/disk/QtopiaHome/Settings/Trolltech/qpe.conf': No such file or directory
ln: /mnt/disk/QtopiaHome/Documents: No such file or directory
ls
[root@FORLINX6410]# ls
bin      etc      linuxrc  opt      root     sdcard   tmp      usr
dev      lib      mnt      proc     sbin     sys      udisk    var
如果将内核配置支持yaffs2文件,同样烧录,则根本进入不了内核,显示结果:
VFS: Mounted root (cramfs filesystem) readonly on device 31:2.
devtmpfs: mounted
Freeing init memory: 160K
/etc/rc.d/init.d/netd: line 16: /usr/sbin/inetd: not found
yaffs: passed flags ""
Unable to handle kernel paging request at virtual address 87cac208
pgd = c0004000
[87cac208] *pgd=00000000
Internal error: Oops: 805 [#1]
last sysfs file: /sys/class/i2c-dev/i2c-1/dev
Modules linked in:
CPU: 0    Not tainted  (2.6.36.2 #2)
PC is at s3c_nand_write_page_8bit+0xc0/0xf8
LR is at 0x52
pc : [<c025a614>]    lr : [<00000052>]    psr: 20000013
sp : c7b4bc50  ip : 000000b5  fp : c7b4bc7c
r10: c780c000  r9 : c0704d90  r8 : 00000000
r7 : 00000068  r6 : c7942180  r5 : c7942000  r4 : 00000052
r3 : c0704ed4  r2 : 00000008  r1 : c780d200  r0 : c049f008
Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 00c5387d  Table: 57174008  DAC: 00000017
Process yaffs-bg-1 (pid: 74, stack limit = 0xc7b4a268)
Stack: (0xc7b4bc50 to 0xc7b4c000)
bc40:                                     00000000 c7942180 c7942000 c7817000
bc60: 0002a880 c7942000 00001000 c7942180 c7b4bca4 c7b4bc80 c02544e4 c025a560
bc80: 00000010 c7b4bd74 00000010 c7b4bd74 00001000 c7817000 c7b4bd0c c7b4bca8
bca0: c025554c c02544a0 00000000 00000000 c7b4bdb0 00000000 00740000 00000000
bcc0: 00000000 0002a880 0002a880 0000007f 00000000 00000014 c7b4bda4 c7817000
bce0: 00000000 c7b4bd74 c7942000 2a880000 00000000 c7b4bd94 00000010 c78f7a00
bd00: c7b4bd34 c7b4bd10 c025573c c0255310 c7b4bd74 c06f5b64 07e00000 00000000
bd20: 22a80000 00000000 c7b4bd5c c7b4bd38 c024ec08 c02556d0 c7b4bd74 c7b4bd48
bd40: c024eb7c c7b4beb8 00001000 c7817000 c7b4bddc c7b4bd60 c01ab9f4 c024eb88
bd60: c7b4bd74 c0256e5c c7b4bdb0 00022a80 00022b00 00000001 00001000 00000000
bd80: 00000010 c7b58000 00000000 c7817000 c7b4bd94 00001456 000005af 000001b3
bda0: 00001000 00000000 00000000 00000001 00000000 c7816000 c7b4beb8 00022a80
bdc0: c7817000 00000001 00000000 00000001 c7b4bdfc c7b4bde0 c01aa498 c01ab91c
bde0: c7b6a2a8 00000080 c7816000 00022b00 c7b4be84 c7b4be00 c01a494c c01aa424
be00: 0000016e 00000001 c7b4beb8 c7817000 c7b4be84 c7b4be20 c01aa564 c01ab574
be20: c7930a0c 00000001 c7b4be64 00000000 c00417b8 c004ce84 00000001 c06e7518
be40: c7b39730 00000003 c7b39700 3ccbf700 00000000 c06e7518 c7b4be84 c7b501f0
be60: c7b68b68 c7816000 0000016e c06f5b64 c7817000 0000b700 c7b4bf2c c7b4be88
be80: c01a5fe0 c01a47c0 c7924530 3ccbf700 00000000 c06e7518 1065aa00 00000001
bea0: 00000000 00000001 00000000 c06e7518 00061080 00000005 aaaaaaaa 00000001
bec0: 000005af 000001b3 00001000 00000001 00000000 00000000 00000001 00001456
bee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 55555555
bf00: c04a20b8 c7816000 00000080 00000c21 ffff9059 c7816000 c7b4a000 c7b4bf58
bf20: c7b4bf4c c7b4bf30 c01a6c8c c01a5548 00000000 ffff8ff5 ffff8ff4 ffff9059
bf40: c7b4bfbc c7b4bf50 c01a1904 c01a6c64 c0046ba4 c7958940 00000000 00200200
bf60: ffff8ff5 c07488e0 c01a173c c7b39700 ffffffff 00000000 00000000 00000000
bf80: 00000000 00000000 ffffffff 33460dc4 c7b4bfbc c7b41d40 c7816000 c01a1750
bfa0: 00000013 00000000 00000000 00000000 c7b4bff4 c7b4bfc0 c00679d0 c01a175c
bfc0: c7b41d40 00000000 c7816000 00000000 c7b4bfd0 c7b4bfd0 00000000 c7b41d40
bfe0: c0067944 c0031a7c 00000000 c7b4bff8 c0031a7c c0067950 57ffe021 57ffe421
[<c025a614>] (s3c_nand_write_page_8bit+0xc0/0xf8) from [<c02544e4>] (nand_write_page+0x50/0xd8)
[<c02544e4>] (nand_write_page+0x50/0xd8) from [<c025554c>] (nand_do_write_ops+0x248/0x3c0)
[<c025554c>] (nand_do_write_ops+0x248/0x3c0) from [<c025573c>] (nand_write_oob+0x78/0xec)
[<c025573c>] (nand_write_oob+0x78/0xec) from [<c024ec08>] (part_write_oob+0x8c/0xc0)
[<c024ec08>] (part_write_oob+0x8c/0xc0) from [<c01ab9f4>] (nandmtd2_WriteChunkWithTagsToNAND+0xe4/0x138)
[<c01ab9f4>] (nandmtd2_WriteChunkWithTagsToNAND+0xe4/0x138) from [<c01aa498>] (yaffs_wr_chunk_tags_nand+0x80/0x100)
[<c01aa498>] (yaffs_wr_chunk_tags_nand+0x80/0x100) from [<c01a494c>] (yaffs_write_new_chunk+0x198/0x534)
[<c01a494c>] (yaffs_write_new_chunk+0x198/0x534) from [<c01a5fe0>] (yaffs_check_gc+0xaa4/0xccc)
[<c01a5fe0>] (yaffs_check_gc+0xaa4/0xccc) from [<c01a6c8c>] (yaffs_bg_gc+0x34/0x64)
[<c01a6c8c>] (yaffs_bg_gc+0x34/0x64) from [<c01a1904>] (yaffs_bg_thread_fn+0x1b4/0x214)
[<c01a1904>] (yaffs_bg_thread_fn+0x1b4/0x214) from [<c00679d0>] (kthread+0x8c/0x94)
[<c00679d0>] (kthread+0x8c/0x94) from [<c0031a7c>] (kernel_thread_exit+0x0/0x8)
Code: e5930004 e596108c e2844001 e1a0e004 (e7c1c000)
---[ end trace 343ec288f5f0c9c7 ]---
KK
 楼主| 发表于 2011-12-16 10:20:37 | 显示全部楼层
按照版主建议采用yaffs2文件系统(光盘中提供),还是会出现类似问题:
VFS: Mounted root (yaffs2 filesystem) on device 31:3.
devtmpfs: mounted
Freeing init memory: 164K
Unable to handle kernel paging request at virtual address 87cad570
pgd = c0004000
[87cad570] *pgd=00000000
last sysfs file:
Modules linked in:
LR is at 0x52
pc : [<c025b5b4>]    lr : [<00000052>]    psr: 20000013
sp : c7989c50  ip : 00000013  fp : c7989c7c
r10: c780c000  r9 : c0704bf8  r8 : 00000000
r7 : 00000068  r6 : c7920180  r5 : c7920000  r4 : 00000052
r3 : c0704d3c  r2 : 00000008  r1 : c780d200  r0 : c04a0370
Control: 00c5387d  Table: 50004008  DAC: 00000017
Process yaffs-bg-1 (pid: 44, stack limit = 0xc7988268)
Stack: (0xc7989c50 to 0xc798a000)
9c40:                                     00000000 c7920180 c7920000 c7960000
9c60: 0002a300 c7920000 00001000 c7920180 c7989ca4 c7989c80 c0255484 c025b500
9c80: 00000010 c7989d74 00000010 c7989d74 00001000 c7960000 c7989d0c c7989ca8
9ca0: c02564ec c0255440 00000000 00000000 c7989db0 00000000 fffff000 ffffffff
9cc0: 00000000 0002a300 0002a300 0000007f 00000000 00000014 c7989da4 c7960000
9ce0: 00000000 c7989d74 c7920000 2a300000 00000000 c7989d94 00000010 c78f6a00
9d00: c7989d34 c7989d10 c02566dc c02562b0 c7989d74 c06f59cc 07e00000 00000000
9d20: 22500000 00000000 c7989d5c c7989d38 c024fba8 c0256670 c7989d74 c7989d48
9d40: c024fb1c c7989eb8 00001000 c7960000 c7989ddc c7989d60 c01ac984 c024fb28
9d60: c7989d74 c0257dfc c7989db0 00022500 00022580 00000001 00001000 00000000
9d80: 00000010 c7961000 00000000 c7960000 c7989d94 0000144b 000005a3 0000000d
9da0: 00001000 00000000 00000000 00000001 00000000 c7817000 c7989eb8 00022500
9dc0: c7960000 00000001 00000000 00000001 c7989dfc c7989de0 c01ab428 c01ac8ac
9de0: c799a250 00000080 c7817000 00022580 c7989e84 c7989e00 c01a58dc c01ab3b4
9e00: 00000169 00000001 c7989eb8 c7960000 c7989e84 c7989e20 c01ab4f4 c01ac504
9e20: c0047b34 c009cbec 00000000 00000000 c06f00e0 00000000 c7989e8c c7989e48
9e40: c04a3420 c0047b08 00000000 c04a3c08 c7918268 c7988000 c7989e84 c79801f0
9e60: c7998b40 c7817000 00000169 c06f59cc c7960000 0000b480 c7989f2c c7989e88
9e80: c01a6f70 c01a5750 c04a3c08 c04a3088 00000000 c06e7380 b1079a00 00000001
9ea0: 00000000 00000001 00000000 c06e7380 00061280 00000005 aaaaaaaa 00000001
9ec0: 000005a3 0000000d 00001000 00000001 00000000 00000000 00000001 0000144b
9ee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 55555555
9f00: c7918000 c7817000 00000080 00000c25 ffff8fbd c7817000 c7988000 c7989f58
9f20: c7989f4c c7989f30 c01a7c1c c01a64d8 00000000 ffff8f59 ffff8f54 ffff8fbd
9f40: c7989fbc c7989f50 c01a2894 c01a7bf4 c0047b34 c7956880 00000000 00200200
9f60: ffff8f55 c07487c0 c01a26cc c7918000 ffffffff 00000000 00000000 00000000
9f80: 00000000 00000000 ffffffff 5ba05741 c7989fbc c7825ca8 c7817000 c01a26e0
9fa0: 00000013 00000000 00000000 00000000 c7989ff4 c7989fc0 c0068960 c01a26ec
9fc0: c7825ca8 00000000 c7817000 00000000 c7989fd0 c7989fd0 00000000 c7825ca8
9fe0: c00688d4 c0032a7c 00000000 c7989ff8 c0032a7c c00688e0 00000000 00000000
[<c025b5b4>] (s3c_nand_write_page_8bit+0xc0/0xf8) from [<c0255484>] (nand_write_page+0x50/0xd8)
[<c0255484>] (nand_write_page+0x50/0xd8) from [<c02564ec>] (nand_do_write_ops+0x248/0x3c0)
[<c02564ec>] (nand_do_write_ops+0x248/0x3c0) from [<c02566dc>] (nand_write_oob+0x78/0xec)
[<c02566dc>] (nand_write_oob+0x78/0xec) from [<c024fba8>] (part_write_oob+0x8c/0xc0)
[<c024fba8>] (part_write_oob+0x8c/0xc0) from [<c01ac984>] (nandmtd2_WriteChunkWithTagsToNAND+0xe4/0x138)
[<c01ac984>] (nandmtd2_WriteChunkWithTagsToNAND+0xe4/0x138) from [<c01ab428>] (yaffs_wr_chunk_tags_nand+0x80/0x100)
[<c01ab428>] (yaffs_wr_chunk_tags_nand+0x80/0x100) from [<c01a58dc>] (yaffs_write_new_chunk+0x198/0x534)
[<c01a58dc>] (yaffs_write_new_chunk+0x198/0x534) from [<c01a6f70>] (yaffs_check_gc+0xaa4/0xccc)
[<c01a6f70>] (yaffs_check_gc+0xaa4/0xccc) from [<c01a7c1c>] (yaffs_bg_gc+0x34/0x64)
[<c01a7c1c>] (yaffs_bg_gc+0x34/0x64) from [<c01a2894>] (yaffs_bg_thread_fn+0x1b4/0x214)
[<c01a2894>] (yaffs_bg_thread_fn+0x1b4/0x214) from [<c0068960>] (kthread+0x8c/0x94)
[<c0068960>] (kthread+0x8c/0x94) from [<c0032a7c>] (kernel_thread_exit+0x0/0x8)
---[ end trace cef44c942735fa2f ]---
采用光盘中Demo内核文件是没有问题的,希望各位大侠给点建议............
发表于 2011-12-16 16:34:34 | 显示全部楼层
请贴烧写映像来源、烧写步骤。
 楼主| 发表于 2011-12-17 09:11:58 | 显示全部楼层
烧录步骤是采用《OK6410-A开发板LINUX2.6.36用户手册.pdf》中的USB烧录方式,UBOOT和FORLINX_6410_touch.cramfs使用光盘中提供的,如果内核烧录光盘中的DEMO文件zImage,那么启动QT是正常的,如果使用我自己编译的内核(在http://www.kernel.org上下载的Linux-2.6.36.2源码加以修改)就出现上面的问题。。。。。。。。。。
发表于 2011-12-17 16:16:22 | 显示全部楼层
移植内核时出了致命的错误。需要修改源码。
祝楼主早日移植成功。
 楼主| 发表于 2011-12-19 09:40:13 | 显示全部楼层
应该是内核移植的问题,开始我是怀疑没加LCD驱动才这样,现在我把DM9000和LCD的驱动也加进去了,但是还是如此情况,版主有没有好的建议?
CPU: ARMv6-compatible processor [410fb766] revision 6 (ARMv7), cr=00c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: SMDK6410
CPU S3C6410 (id 0x36410101)
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Kernel command line: root=/dev/mtdblock2 rootfstype=cramfs console=ttySAC0,115200 init=/linuxrc
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 122152k/122152k available, 8920k reserved, 0K highmem
Virtual kernel memory layout:
    vmalloc : 0xc8800000 - 0xe0000000   ( 376 MB)
    lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
      .init : 0xc0008000 - 0xc0031000   ( 164 kB)
      .text : 0xc0031000 - 0xc0672000   (6404 kB)
      .data : 0xc06cc000 - 0xc0715500   ( 294 kB)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
        RCU-based detection of stalled CPUs is disabled.
        Verbose stalled-CPUs detection is disabled.
NR_IRQS:246
console [ttySAC0] enabled
Calibrating delay loop... 530.84 BogoMIPS (lpj=2654208)
devtmpfs: initialized
s3c64xx_dma_init1: registering DMA 0 (c8808100)
s3c64xx_dma_init1: registering DMA 1 (c8808120)
s3c64xx_dma_init1: registering DMA 2 (c8808140)
s3c64xx_dma_init1: registering DMA 3 (c8808160)
s3c64xx_dma_init1: registering DMA 4 (c8808180)
s3c64xx_dma_init1: registering DMA 5 (c88081a0)
s3c64xx_dma_init1: registering DMA 6 (c88081c0)
s3c64xx_dma_init1: registering DMA 7 (c88081e0)
PL080: IRQ 73, at c8808000
s3c64xx_dma_init1: registering DMA 8 (c880c100)
s3c64xx_dma_init1: registering DMA 9 (c880c120)
s3c64xx_dma_init1: registering DMA 10 (c880c140)
s3c64xx_dma_init1: registering DMA 11 (c880c160)
s3c64xx_dma_init1: registering DMA 12 (c880c180)
s3c64xx_dma_init1: registering DMA 13 (c880c1a0)
s3c64xx_dma_init1: registering DMA 14 (c880c1c0)
s3c64xx_dma_init1: registering DMA 15 (c880c1e0)
PL080: IRQ 74, at c880c000
S3C6410: Initialising architecture
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
s3c-i2c s3c2440-i2c.1: no platform data
s3c-i2c: probe of s3c2440-i2c.1 failed with error -22
Advanced Linux Sound Architecture Driver Version 1.0.23.
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
msgmni has been set to 238
io scheduler noop registered
 楼主| 发表于 2011-12-19 09:40:53 | 显示全部楼层
S3C_LCD clock got enabled :: 133.000 Mhz
LCD TYPE :: LTE480WV will be initialized
Window[0] - FB1: map_video_memory: clear ff600000:0007f800
            FB1: map_video_memory: dma=57980000 cpu=ff600000 size=0007f800
Window[0] - FB2: map_video_memory: clear ff63fc00:0003fc00
            FB2: map_video_memory: dma=579bfc00 cpu=ff63fc00 size=0003fc00
Console: switching to colour frame buffer device 60x34
Window[1] - FB1: map_video_memory: clear ff700000:0007f800
            FB1: map_video_memory: dma=57a00000 cpu=ff700000 size=0007f800
Window[1] - FB2: map_video_memory: clear ff73fc00:0003fc00
            FB2: map_video_memory: dma=57a3fc00 cpu=ff73fc00 size=0003fc00
Window[2] - FB1: map_video_memory: clear ff680000:0003fc00
            FB1: map_video_memory: dma=57940000 cpu=ff680000 size=0003fc00
Window[3] - FB1: map_video_memory: clear ff780000:0003fc00
            FB1: map_video_memory: dma=57a80000 cpu=ff780000 size=0003fc00
jkq debug VIDCON0 is 353
s3c6400-uart.0: s3c2410_serial0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10
s3c6400-uart.1: s3c2410_serial1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10
s3c6400-uart.2: s3c2410_serial2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10
s3c6400-uart.3: s3c2410_serial3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10
S3C NAND Driver, (c) 2008 Samsung Electronics
dev_id == 0xd5 select s3c_nand_oob_mlc_128
S3C NAND Driver is using hardware ECC.
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd5 (Samsung NAND 2GiB 3,3V 8-bit)
Creating 4 MTD partitions on "NAND 2GiB 3,3V 8-bit":
0x000000000000-0x000000100000 : "Bootloader"
0x000000100000-0x000000600000 : "Kernel"
0x000000600000-0x000007e00000 : "User"
0x000007e00000-0x000080000000 : "File System"
dm9000 Ethernet Driver, V1.31
eth0: dm9000a at c8826000,c8c00004 IRQ 108 MAC: 08:90:00:a0:90:90 (platform data)
libertas_sdio: Libertas SDIO driver
libertas_sdio: Copyright Pierre Ossman
usbcore: registered new interface driver rt73usb
s3c2410-ohci s3c2410-ohci: init err (00000000 0000)
ohci_hcd: can't start s3c24xx
s3c2410-ohci s3c2410-ohci: startup error -75
s3c2410-ohci s3c2410-ohci: USB bus 1 deregistered
s3c2410-ohci: probe of s3c2410-ohci failed with error -75
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver pl2303
mice: PS/2 mouse device common for all mice
S3C Touchscreen driver, (c) 2008 Samsung Electronics
S3C TouchScreen got loaded successfully : 12 bits
input: S3C TouchScreen as /class/input/input0
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
i2c /dev entries driver
lirc_dev: IR Remote Control driver registered, major 253
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR LIRC bridge handler initialized
Linux video capture interface: v2.00
usbcore: registered new interface driver em28xx
em28xx driver loaded
Em28xx: Initialized (Em28xx Audio Extension) extension
cx231xx v4l2 driver loaded.
usbcore: registered new interface driver cx231xx
cx231xx: Cx231xx Audio Extension initialized
usbcore: registered new interface driver usbvision
USBVision USB Video Device Driver for Linux : 0.9.10
usbcore: registered new interface driver pvrusb2
pvrusb2: V4L in-tree version:Hauppauge WinTV-PVR-USB2 MPEG2 Encoder/Tuner
pvrusb2: Debug mask is 31 (0x1f)
SE401 usb camera driver version 0.24 registering
usbcore: registered new interface driver se401
usbcore: registered new interface driver zr364xx
zr364xx: Zoran 364xx
usbcore: registered new interface driver stkwebcam
sn9c102: V4L2 driver for SN9C1xx PC Camera Controllers v1:1.47pre49
usbcore: registered new interface driver sn9c102
pwc: Philips webcam module version 10.0.13 loaded.
pwc: Supports Philips PCA645/646, PCVC675/680/690, PCVC720[40]/730/740/750 & PCVC830/840.
pwc: Also supports the Askey VC010, various Logitech Quickcams, Samsung MPC-C10 and MPC-C30,
pwc: the Creative WebCam 5 & Pro Ex, SOTEC Afina Eye and Visionite VCS-UC300 and VCS-UM100.
usbcore: registered new interface driver Philips webcam
gspca: main v2.10.0 registered
usbcore: registered new interface driver hdpvr
usbcore: registered new interface driver ibmcam
usbcore: registered new interface driver ultracam
konicawc: v1.4:Konica Webcam driver
usbcore: registered new interface driver konicawc
usbcore: registered new interface driver vicam
usbcore: registered new interface driver s2255
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
sdhci: Secure Digital Host Controller Interface driver
usbhid: USB HID core driver
ALSA device list:
  No soundcards found.
TCP cubic registered
s3c6400_setup_sdhci_cfg_card: CTRL 2=c0004120, 3=80808080
s3c-rtc s3c64xx-rtc: setting system clock to 2011-11-19 09:23:41 UTC (1321694621)
mtd->size = 80000 blocks = 7800000
cheaking bad block...............
devtmpfs: mounted
mount: mounting /dev/mtdblock3 on /mnt/disk failed: No such device
Try to bring eth0 interface up......eth0: link down
Done
ls^H^H
GMT+8, 2026-10-6 06:19
