查看: 9353|回复: 7
求助 build solution
发表于 2012-2-1 22:09:46 | 显示全部楼层 |阅读模式
build solution 后为什么没有出现可执行文件(.exe)?
发表于 2012-2-2 08:37:54 | 显示全部楼层
你这主题写的,连个头都没有啊~
你编译什么啊?
 楼主| 发表于 2012-2-2 20:44:38 | 显示全部楼层
按手册操作4-4编写第一个应用程序,结果没有手册说的  生成可执行文件
发表于 2012-2-3 08:30:13 | 显示全部楼层
你把你的操作过程,全部发上来~
不生成,也会有出错信息啊~
 楼主| 发表于 2012-2-3 13:21:39 | 显示全部楼层
------ Build started: Project: ff, Configuration: Release TE6410 Board (ARMV4I) ------
Compiling...
stdafx.cpp
E:\win6.0\WinCE6.0\SDK\sdksetup\include\ARMV4I\malloc.h(45) : error C2143: syntax error : missing ',' before '*'
e:\vs2005\vs\VS2005\vssetup\VC\ce\atlmfc\include\atlosapice.h(879) : warning C4996: 'wcsncpy' was declared deprecated
        e:\win6.0\wince6.0\sdk\sdksetup\include\armv4i\stdlib.h(177) : see declaration of 'wcsncpy'
        Message: 'This function or variable may be unsafe. Consider using wcsncpy_s instead. To disable deprecation, use _CRT_SECURE_NO_DEPRECATE. See online help for details.'
e:\vs2005\vs\VS2005\vssetup\VC\ce\atlmfc\include\atlosapice.h(1075) : warning C4996: 'wcsncpy' was declared deprecated
e:\vs2005\vs\VS2005\vssetup\VC\ce\atlmfc\include\atlosapice.h(1123) : warning C4996: 'wcsncpy' was declared deprecated
e:\vs2005\vs\VS2005\vssetup\VC\ce\atlmfc\include\atltime.h(402) : error C3861: 'wcsftime': identifier not found
e:\vs2005\vs\VS2005\vssetup\VC\ce\atlmfc\include\atltime.h(429) : error C3861: 'wcsftime': identifier not found
e:\vs2005\vs\VS2005\vssetup\VC\ce\atlmfc\include\atlcomtime.h(367) : error C3861: 'wcsftime': identifier not found
Build log was saved at "file://e:\vs2005\vs\VS2005\vssetup\Common7\IDE\lianxi1\ff\ff\TE6410 Board (ARMV4I)\Release\BuildLog.htm"
ff - 4 error(s), 3 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
发表于 2012-2-3 16:50:47 | 显示全部楼层
先看看这个对吗?
 楼主| 发表于 2012-2-5 08:11:05 | 显示全部楼层
解决了,谢谢
发表于 2012-2-6 08:17:02 | 显示全部楼层
:P
GMT+8, 2026-9-26 10:02
