- 积分
- 4373
贡献13598
飞刀4837 FD
注册时间2015-12-16
在线时间1173 小时
发表于 2012-2-16 12:59:10
显示全部楼层
飞凌提供的是32位版的,要在64位的系统上编译要改一下代码
下面给出方法
The given source code is supposed to be build under 64-bits ubuntu linux
if you are using 32-bit system, please follow the instructions.
光盘的代码应该在64位的系统下编译,如果你使用的是32位系统,请做以下修改:
1.Modify the following files
./external/clearsilver/cgi/Android.mk
./external/clearsilver/java-jni/Android.mk
./external/clearsilver/util/Android.mk
./external/clearsilver/cs/Android.mk
find
LOCAL_CFLAGS += -m64
LOCAL_LDFLAGS += -m64
replace with
LOCAL_CFLAGS += -m32
LOCAL_LDFLAGS += -m32
2.Modify ./build/core/main.mk
find
ifneq (64,$(findstring 64,$(build_arch)))
replace with
ifneq (i686,$(findstring i686,$(build_arch))) |
