查看: 3566|回复: 1
TE-2440根文件系统制作出现问题
发表于 2012-2-16 15:00:46 | 显示全部楼层 |阅读模式
我自己制作的根文件系统,烧入板子后,出现了问题:如下
Partially written block 148 detected
yaffs tragedy: attempting to use non-directory as a directory in scan. Put in lost+found.
yaffs tragedy: Bad object type, 1 != 3, for object 282 at chunk 3178 during scan
VFS: Mounted root (yaffs filesystem) on device 31:3.
Freeing init memory: 100K
cannot run '/etc/init.d/rcS': No such file or directory
Please press Enter to activate this console.
发现 /etc目录没有了,而且里面的所有文件都进入到 lost+found 文件里
/lost+found # ls
LCK..s3c2410_serial1  init.d                resolv.conf
default.script        inittab
fstab                 ppp
求解:
发表于 2012-2-16 16:51:00 | 显示全部楼层
你怎么压缩的文件系统?
GMT+8, 2026-10-6 02:55
