查看: 3901|回复: 4
内核无法挂载YAFFS2文件系统
发表于 2012-2-17 20:56:28 | 显示全部楼层 |阅读模式
嘿,各位,如题。以下是我的内核启动信息,请有经验人士帮忙指点下,谢谢:
Starting kernel ...
Linux version 2.6.36.2 (root@ubuntu) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #382 Thu Feb 16 20:52:15 CST 2012
CPU: ARMv6-compatible processor [410fb766] revision 6 (ARMv7), cr=00c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: SMDK6410
CPU S3C6410 (id 0x36410101)
s3c64xx: 10485760 bytes SDRAM reserved for fimc at 0x5f5f9000
s3c64xx: 8388608 bytes SDRAM reserved for tv at 0x5edf9000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: root=/dev/mtdblock3 rootfstype=yaffs2 init=/sbin/init console=ttySAC0,115200
PID hash table entries: 1024 (order: 0, 4096 bytes)
Memory: 256MB = 256MB total
Memory: 232860k/232860k available, 29284k reserved, 0K highmem
Virtual kernel memory layout:
    vmalloc : 0xd0800000 - 0xe0000000   ( 248 MB)
    lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
      .init : 0xc0008000 - 0xc0034000   ( 176 kB)
      .text : 0xc0034000 - 0xc072a000   (7128 kB)
      .data : 0xc078e000 - 0xc07dcc80   ( 316 kB)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
        RCU-based detection of stalled CPUs is disabled.
        Verbose stalled-CPUs detection is disabled.
NR_IRQS:246
console [ttySAC0] enabled
Calibrating delay loop... 530.84 BogoMIPS (lpj=2654208)
devtmpfs: initialized
s3c64xx_dma_init1: registering DMA 0 (d0808100)
s3c64xx_dma_init1: registering DMA 1 (d0808120)
s3c64xx_dma_init1: registering DMA 2 (d0808140)
s3c64xx_dma_init1: registering DMA 3 (d0808160)
s3c64xx_dma_init1: registering DMA 4 (d0808180)
s3c64xx_dma_init1: registering DMA 5 (d08081a0)
s3c64xx_dma_init1: registering DMA 6 (d08081c0)
s3c64xx_dma_init1: registering DMA 7 (d08081e0)
PL080: IRQ 73, at d0808000
s3c64xx_dma_init1: registering DMA 8 (d080c100)
s3c64xx_dma_init1: registering DMA 9 (d080c120)
s3c64xx_dma_init1: registering DMA 10 (d080c140)
s3c64xx_dma_init1: registering DMA 11 (d080c160)
s3c64xx_dma_init1: registering DMA 12 (d080c180)
s3c64xx_dma_init1: registering DMA 13 (d080c1a0)
s3c64xx_dma_init1: registering DMA 14 (d080c1c0)
s3c64xx_dma_init1: registering DMA 15 (d080c1e0)
PL080: IRQ 74, at d080c000
S3C6410: Initialising architecture
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
Advanced Linux Sound Architecture Driver Version 1.0.23.
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
audit: initializing netlink socket (disabled)
type=2000 audit(0.510:1): initialized
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
msgmni has been set to 454
io scheduler noop registered
S3C_LCD clock got enabled :: 133.000 Mhz
LCD TYPE :: LTE480WV will be initialized
Window[0] - FB1: map_video_memory: clear ff600000:0007f800
            FB1: map_video_memory: dma=5e980000 cpu=ff600000 size=0007f800
Window[0] - FB2: map_video_memory: clear ff63fc00:0003fc00
            FB2: map_video_memory: dma=5e9bfc00 cpu=ff63fc00 size=0003fc00
Console: switching to colour frame buffer device 60x34
Window[1] - FB1: map_video_memory: clear ff700000:0007f800
            FB1: map_video_memory: dma=5ea00000 cpu=ff700000 size=0007f800
Window[1] - FB2: map_video_memory: clear ff73fc00:0003fc00
            FB2: map_video_memory: dma=5ea3fc00 cpu=ff73fc00 size=0003fc00
Window[2] - FB1: map_video_memory: clear ff680000:0003fc00
            FB1: map_video_memory: dma=5ea80000 cpu=ff680000 size=0003fc00
Window[3] - FB1: map_video_memory: clear ff780000:0003fc00
            FB1: map_video_memory: dma=5eac0000 cpu=ff780000 size=0003fc00
jkq debug VIDCON0 is 353
leds        initialized
pwm        initialized
s3c6400-uart.0: s3c2410_serial0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10
s3c6400-uart.1: s3c2410_serial1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10
s3c6400-uart.2: s3c2410_serial2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10
s3c6400-uart.3: s3c2410_serial3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10
S3C NAND Driver, (c) 2008 Samsung Electronics
dev_id == 0xd5 select s3c_nand_oob_mlc_128
S3C NAND Driver is using hardware ECC.
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd5 (Samsung NAND 2GiB 3,3V 8-bit)
Creating 4 MTD partitions on "NAND 2GiB 3,3V 8-bit":
0x000000000000-0x000000100000 : "Bootloader"
0x000000100000-0x000000600000 : "Kernel"
0x000000600000-0x000007e00000 : "User"
0x000007e00000-0x000080000000 : "File System"
dm9000 Ethernet Driver, V1.31
eth0: dm9000a at d0826000,d0c00004 IRQ 108 MAC: 08:90:00:a0:90:90 (platform data)
libertas_sdio: Libertas SDIO driver
libertas_sdio: Copyright Pierre Ossman
usbcore: registered new interface driver rt73usb
s3c2410-ohci s3c2410-ohci: init err (00000000 0000)
ohci_hcd: can't start s3c24xx
(接下楼)
 楼主| 发表于 2012-2-17 20:57:03 | 显示全部楼层
s3c2410-ohci s3c2410-ohci: startup error -75
s3c2410-ohci s3c2410-ohci: USB bus 1 deregistered
s3c2410-ohci: probe of s3c2410-ohci failed with error -75
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver pl2303
mice: PS/2 mouse device common for all mice
input: gpio-keys as /class/input/input0
S3C Touchscreen driver, (c) 2008 Samsung Electronics
S3C TouchScreen got loaded successfully : 12 bits
input: S3C TouchScreen as /class/input/input1
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
i2c /dev entries driver
lirc_dev: IR Remote Control driver registered, major 253
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR LIRC bridge handler initialized
Linux video capture interface: v2.00
usbcore: registered new interface driver em28xx
em28xx driver loaded
Em28xx: Initialized (Em28xx Audio Extension) extension
cx231xx v4l2 driver loaded.
usbcore: registered new interface driver cx231xx
cx231xx: Cx231xx Audio Extension initialized
usbcore: registered new interface driver usbvision
USBVision USB Video Device Driver for Linux : 0.9.10
usbcore: registered new interface driver pvrusb2
pvrusb2: V4L in-tree version:Hauppauge WinTV-PVR-USB2 MPEG2 Encoder/Tuner
pvrusb2: Debug mask is 31 (0x1f)
SE401 usb camera driver version 0.24 registering
usbcore: registered new interface driver se401
usbcore: registered new interface driver zr364xx
zr364xx: Zoran 364xx
usbcore: registered new interface driver stkwebcam
sn9c102: V4L2 driver for SN9C1xx PC Camera Controllers v1:1.47pre49
usbcore: registered new interface driver sn9c102
pwc: Philips webcam module version 10.0.13 loaded.
pwc: Supports Philips PCA645/646, PCVC675/680/690, PCVC720[40]/730/740/750 & PCVC830/840.
pwc: Also supports the Askey VC010, various Logitech Quickcams, Samsung MPC-C10 and MPC-C30,
pwc: the Creative WebCam 5 & Pro Ex, SOTEC Afina Eye and Visionite VCS-UC300 and VCS-UM100.
usbcore: registered new interface driver Philips webcam
gspca: main v2.10.0 registered
usbcore: registered new interface driver hdpvr
usbcore: registered new interface driver ibmcam
usbcore: registered new interface driver ultracam
konicawc: v1.4:Konica Webcam driver
usbcore: registered new interface driver konicawc
usbcore: registered new interface driver vicam
usbcore: registered new interface driver s2255
[CAM]s3c_fimc_register_controller.id=0
s3c_fimc_init_global s3c_fimc.cam_clock=-1065795124
[CAM]s3c_fimc_register_controller.id=1
s3c-fimc: info ov965x_init
[CAM]s3c_fimc_register_camera,cam->id=0
s3c_fimc.cam_clock = c07941cc
parent clock for camera: 266.000 MHz, divisor: 11
[CAM]RESET CAM.[CAM]Reset and init reg!1cam->client=ce851900
[CAM]Reset and init reg!2
[CAM]s3c_fimc_init_camera[CAM]I2C_CAM_INIT.
[CAM]s3c_fimc_init_camera[CAM]s3c_fimc_init_camera[CAM]Reset and init reg!3
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
sdhci: Secure Digital Host Controller Interface driver
s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (24000000 Hz)
enter s3c64xx_setup_sdhci1_cfg_gpio
s3c6400_setup_sdhci_cfg_card: CTRL 2=c0004120, 3=80808080
usbhid: USB HID core driver
asoc: AC97 HiFi <-> s3c-ac97 mapping ok
s3c6400_setup_sdhci_cfg_card: CTRL 2=c0004100, 3=00008080
mmc0: new high speed SD card at address 0001
mmcblk0: mmc0:0001 APPSD 946 MiB
mmcblk0: p1
ALSA device list:
  #0: SMDK (WM9713)
TCP cubic registered
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
s3c-rtc s3c64xx-rtc: setting system clock to 2012-02-17 20:38:38 UTC (1329511118)
yaffs: passed flags ""
VFS: Mounted root (yaffs2 filesystem) on device 31:3.
devtmpfs: mounted
Freeing init memory: 176K
Kernel panic - not syncing: Attempted to kill init!
[<c003aa8c>] (unwind_backtrace+0x0/0xfc) from [<c052d5a4>] (dump_stack+0x18/0x1c)
[<c052d5a4>] (dump_stack+0x18/0x1c) from [<c052d608>] (panic+0x60/0x1a8)
[<c052d608>] (panic+0x60/0x1a8) from [<c0053030>] (do_exit+0x674/0x6a4)
[<c0053030>] (do_exit+0x674/0x6a4) from [<c00530a4>] (do_group_exit+0x44/0xb4)
[<c00530a4>] (do_group_exit+0x44/0xb4) from [<c0062100>] (get_signal_to_deliver+0x1cc/0x384)
[<c0062100>] (get_signal_to_deliver+0x1cc/0x384) from [<c0037570>] (do_notify_resume+0xac/0x5d0)
[<c0037570>] (do_notify_resume+0xac/0x5d0) from [<c0034a78>] (work_pending+0x24/0x28)
发表于 2012-2-18 10:48:30 | 显示全部楼层
飞凌提供的zImang是可以用的
试试光盘里的内核
 楼主| 发表于 2012-2-18 15:18:31 | 显示全部楼层
内核镜像应该是没问题的啊,cramfs都可以正常挂载啊
发表于 2012-2-20 08:46:03 | 显示全部楼层
修改过什么?
GMT+8, 2026-10-6 02:52
