查看: 3210|回复: 1
TE2440-II 核心板启动问题,请求帮助
发表于 2012-2-24 13:04:47 | 显示全部楼层 |阅读模式
设置启动WINCE,核心板通过串口打印了一些信息,不能加载WINCE,不知是什么原因?恳请帮助,多谢!
串口打印信息如下:
|   Forlinx 2440 Bootloader VER-6.0        www.witech.com.cn |
|CPU ID is 0x32440001                                        |
|FCLK=400MHz,HCLK=100MHz,PCLK=50MHz, CPU is running at 400MHz|
|UPLL=96MHz, UCLK=48MHz                                      |
|Serial port 0, Baud rate is 115200.                         |
|OS image stored in NAND Flash.                              |
|Autoboot delay is 7 seconds.                                |
|Initial VGA now, Please wait...                             |
|VGA init done (VGA MODE 800*600)                            |
Load eboot...
run 0x30038000...
Microsoft Windows CE Ethernet Bootloader Common Library Version 1.1 Built Mar  3 2010 15:20:51
Microsoft Windows CE Bootloader for the Samsung SMDK2440 Version 2.4 Built Mar  3 2010
FMD: ReadID (Mfg=ec, Dev=da)
FMD_Init: finished successful
FMD_Init: reserved_blocks 548
FMD_GetInfo
Initiating image launch in 5 seconds.
发表于 2012-2-24 13:07:48 | 显示全部楼层
按一下空格,进入bootloader。选择wince
GMT+8, 2026-10-6 01:48
