查看: 543|回复: 0
[Linux] OK3399核心板搭载7寸的mipi屏幕触摸没有反应
RK3588通行证
发表于 2026-5-26 17:55:07 | 显示全部楼层 |阅读模式
我使用OK3399核心板搭载7寸的mipi屏幕,镜像固件使用的是原版的,但是在触摸时屏幕没有反应[root@rk3399:/]# cat /proc/bus/input/devices
I: Bus=0001 Vendor=1234 Product=5678 Version=0001
N: Name="InputEmulator"
P: Phys=
S: Sysfs=/devices/virtual/input/input0
U: Uniq=
H: Handlers=kbd event0 cpufreq
B: PROP=0
B: EV=100003
B: KEY=ffffffffffffffff ffffffffffffffff ffffffffffffffff fffffffffffffffe
I: Bus=0018 Vendor=0000 Product=0000 Version=0000
N: Name="EP0790M09"
P: Phys=
S: Sysfs=/devices/platform/ff110000.i2c/i2c-1/1-0038/input/input1
U: Uniq=
H: Handlers=event1 cpufreq
B: PROP=2
B: EV=b
B: KEY=400 0 0 0 0 0
B: ABS=260800000000003
I: Bus=0000 Vendor=0000 Product=0000 Version=0000
N: Name="Typec_Headphone"
P: Phys=fusb302/typec
S: Sysfs=/devices/platform/ff160000.i2c/i2c-7/7-0022/input/input2
U: Uniq=
H: Handlers=event2
B: PROP=0
B: EV=21
B: SW=4
I: Bus=0000 Vendor=0001 Product=0001 Version=0100
N: Name="rk_headset"
P: Phys=
S: Sysfs=/devices/platform/rk_headset/input/input3
U: Uniq=
H: Handlers=event3
B: PROP=0
B: EV=3
B: KEY=400000000 0 c000000000000 0
I: Bus=0019 Vendor=0001 Product=0001 Version=0100
N: Name="rk29-keypad"
P: Phys=gpio-keys/input0
S: Sysfs=/devices/platform/rockchip-key/input/input4
U: Uniq=
H: Handlers=event4
B: PROP=0
B: EV=3
B: KEY=8000 1c000000000000 0
[root@rk3399:/]# evtest /dev/input/event1
Input driver version is 1.0.1
Input device ID: bus 0x18 vendor 0x0 product 0x0 version 0x0
Input device name: "EP0790M09"
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 330 (BTN_TOUCH)
  Event type 3 (EV_ABS)
    Event code 0 (ABS_X)
      Value      0
      Min        0
      Max     1023
    Event code 1 (ABS_Y)
      Value      0
      Min        0
      Max      599
    Event code 47 (ABS_MT_SLOT)
      Value      0
      Min        0
      Max        4
    Event code 53 (ABS_MT_POSITION_X)
      Value      0
      Min        0
      Max     1023
    Event code 54 (ABS_MT_POSITION_Y)
      Value      0
      Min        0
      Max      599
    Event code 57 (ABS_MT_TRACKING_ID)
      Value      0
      Min        0
      Max    65535
Properties:
  Property type 1 (INPUT_PROP_DIRECT)
Testing ... (interrupt to exit)
^C[root@rk3399:/]# i2cdetect -r -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- UU -- -- -- -- -- UU -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
[root@rk3399:/]#
GMT+8, 2026-10-4 09:24
