查看: 3491|回复: 2
red hat linux2.6.36 nfs文件系统制作
发表于 2012-3-3 17:21:08 | 显示全部楼层 |阅读模式
OK6410开发板,linux2.6.36
     小弟这几天在学linux系统移植,到了文件系统制作这块,视频讲了initramfs和nfs2中文件系统制作 ,
跟着视频做initramfs文件系统做好了,烧进开发板能运行起来,
   但做好nfs文件系统后,烧进开发板,一直跑不起来。谁遇到过,告诉小弟一下
提示信息如下:usbhid: USB HID core driver
asoc: AC97 HiFi <-> s3c-ac97 mapping ok
s3c6400_setup_sdhci_cfg_card: CTRL 2=c0004100, 3=00008080
mmc0: new high speed SDHC card at address e624
mmcblk0: mmc0:e624 SU04G 3.69 GiB
mmcblk0: p1
s3c6400_setup_sdhci_cfg_card: CTRL 2=c0004120, 3=80808080
ALSA device list:
  #0: SMDK (WM9713)
TCP cubic registered
s3c-rtc s3c64xx-rtc: setting system clock to 2001-03-04 11:40:15 UTC (983706015)
mtd->size = 80000 blocks = 7800000
cheaking bad block...............
1f00            1024 mtdblock0 (driver?)
1f01            5120 mtdblock1 (driver?)
1f02          122880 mtdblock2 (driver?)
1f03         1968128 mtdblock3 (driver?)
b300         3872256 mmcblk0 driver: mmcblk
  b301         3868160 mmcblk0p1
No filesystem could mount root, tried:  cramfs
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,2)
[<c0032a8c>] (unwind_backtrace+0x0/0xfc) from [<c047f428>] (dump_stack+0x18/0x1c
[<c047f428>] (dump_stack+0x18/0x1c) from [<c047f48c>] (panic+0x60/0x1a8)
[<c047f48c>] (panic+0x60/0x1a8) from [<c00090c4>] (mount_block_root+0x1bc/0x25c)
[<c00090c4>] (mount_block_root+0x1bc/0x25c) from [<c0009214>] (mount_root+0xb0/0
xf4)
[<c0009214>] (mount_root+0xb0/0xf4) from [<c0009358>] (prepare_namespace+0x100/0
x19c)
[<c0009358>] (prepare_namespace+0x100/0x19c) from [<c0008670>] (kernel_init+0x11
c/0x168)
[<c0008670>] (kernel_init+0x11c/0x168) from [<c002da7c>] (kernel_thread_exit+0x0
/0x8)
Timer Expired and Para is 5!!
Timer1 Expired and para is 10!!
 楼主| 发表于 2012-3-3 17:22:27 | 显示全部楼层
是我在内核加的定时器,加进去都运行了。
 楼主| 发表于 2012-3-5 18:10:19 | 显示全部楼层
大哥帮我看看
GMT+8, 2026-10-6 00:46
