查看: 3291|回复: 2
关于录音和放音问题,帮忙修改一下
发表于 2012-3-5 09:18:06 | 显示全部楼层 |阅读模式
#include <stdlib.h>
#include <stdio.h>
#include <errno.h>
#include <string.h>
#include <unistd.h>
#include <netdb.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <sys/types.h>
#include <arpa/inet.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <linux/soundcard.h>
#include <termios.h>
#include<sys/stat.h>;
#include<sys/sysinfo.h>;
#include<sys/select.h>;
#define LENGTH   10//录音时间,秒
#define RATE    11025 //采样频率
#define SIZE    8   //量化位数
#define CHANNELS 1   //声道数目
int fd_dev_r;
int fd_dev_w;
int status;
int arg;
int init_dsp()
        fd_dev_r= open("/dev/dsp", O_RDONLY,0777);
        if (fd_dev_r < 0)
           perror("Cannot open /dev/dsp device");
           return 1;
        arg = SIZE;
        status = ioctl(fd_dev_r, SOUND_PCM_WRITE_BITS, &arg);
        if (status == -1)
               perror("Cannot set SOUND_PCM_WRITE_BITS ");
               return 1;
        arg = CHANNELS;
        status = ioctl(fd_dev_r, SOUND_PCM_WRITE_CHANNELS, &arg);
        if (status == -1)
               perror("Cannot set SOUND_PCM_WRITE_CHANNELS");
               return 1;
        arg = RATE;
        status = ioctl(fd_dev_r, SOUND_PCM_WRITE_RATE, &arg);
        if (status == -1)
               perror("Cannot set SOUND_PCM_WRITE_WRITE");
               return 1;
int init_dsp1()
                //打开声卡设备,只写方式;并对声卡进行设置
        fd_dev_w = open("/dev/dsp", O_WRONLY,0777);
        if (fd_dev_w < 0)
               perror("Cannot open0 /dev/dsp device");
               return 1;
        arg = SIZE;
        status = ioctl(fd_dev_w, SOUND_PCM_WRITE_BITS, &arg);//设置量化位数
           if (status == -1)
              perror("Cannot set0 SOUND_PCM_WRITE_BITS ");
            return 1;
        arg = CHANNELS;
        status = ioctl(fd_dev_w, SOUND_PCM_WRITE_CHANNELS, &arg);//设置声道数
        if (status == -1)
            perror("Cannot set0 SOUND_PCM_WRITE_CHANNELS");
               return 1;
        arg = RATE;
        status = ioctl(fd_dev_w, SOUND_PCM_WRITE_RATE, &arg);//设置采样率
           if (status == -1)
               perror("Cannot set0 SOUND_PCM_WRITE_WRITE");
               return 1;
int main()
        int mm=LENGTH*RATE*SIZE*CHANNELS/8;
        char buf[mm];
        while(1)
                init_dsp();
        status = read(fd_dev_r, buf, sizeof(buf));
                if (status != sizeof(buf))
                        perror("read wrong number of bytes");
                close(fd_dev_r);
                init_dsp1();
    status = write(fd_dev_w, buf, sizeof(buf));//送声卡播放
                        perror("wrote wrong number of bytes");
                close(fd_dev_w);
                bzero(buf,mm);
                        return 0;
 楼主| 发表于 2012-3-5 09:18:38 | 显示全部楼层
求指教
发表于 2012-3-5 16:53:23 | 显示全部楼层
修改代码不在技术支持范围
GMT+8, 2026-10-6 00:45
