查看: 2993|回复: 1
start.s 复制代码疑惑
发表于 2012-4-15 10:08:45 | 显示全部楼层 |阅读模式
2440start重定位有这样的代码:
#ifndef CONFIG_SKIP_RELOCATE_UBOOT
relocate:                                /* relocate U-Boot to RAM            */
        adr        r0, _start                /* r0 <- current position of code   */
        ldr        r1, _TEXT_BASE                /* test if we run from flash or RAM */
        cmp     r0, r1                  /* don't reloc during debug         */
        beq     stack_setup
        ldr        r2, _armboot_start
        ldr        r3, _bss_start
        sub        r2, r3, r2                /* r2 <- size of armboot            */
        add        r2, r0, r2                /* r2 <- source end address         */
copy_loop:
        ldmia        r0!, {r3-r10}                /* copy from source address [r0]    */
        stmia        r1!, {r3-r10}                /* copy to   target address [r1]    */
        cmp        r0, r2                        /* until source end addreee [r2]    */
        ble        copy_loop
#endif        /* CONFIG_SKIP_RELOCATE_UBOOT
请问如果是从nandflash启动,复制又是怎么处理的呢,uboot的大小至少也是几十K啊,怎么全都复制到sdram中呢,请高手指点?
发表于 2012-4-15 14:25:28 | 显示全部楼层
回复 1# sylijinlei
  参考我在另外一个论坛的帖子:
http://mcuos.com/thread-7137-1-1.html
GMT+8, 2026-9-22 06:07
